![]() | Home > General (L405) > Clarkson's abrupt change of tune... |
If they were vents then there would be ducting to them from inside the engine bay, there isn't. Land Rover Addict
'Design' - there's no appreciable heat from them - I've owned a 4.4, 4.2, 5.0 and now a 3.6 ... none have 'pumped out heat' from those plastic decorations. I'd say they are as warm as the wings..... Land Rover Addict
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2588 ![]() ![]() |
Heat most certainly does come out of them - how could it not, given that they are where they are? You don't need a direct line of sight for heat to find a way out. |
At even 5mph they would cease to function as vents *if* they were vents, which they are not. Take off the 'vent' and see what's behind it - it's not a gaping hole into the engine bay! Just remember the wings are double skinned. Land Rover Addict
How on earth could they not function as vents with air moving across them when the car is moving? It's a low pressure area, a vent there will extract air (and heat) from wherever is behind it. Open your windows on a cold day and let me know if it gets cold inside ...
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
I shouldn't worry, the panel gaps between the bonnet & front wings on the L322 always ensures perfect cooling |
So...let me get this straight, you think they vent the engine bay - I can't find the astounded emoticon |
This is like pulling teeth. There is heat from the running gear behind the wing panel, be it via conduction, convection, radiation or whatever. The vent in the wing can do nothing but extract that heat via the air flowing across it when the car is moving - whether it is the most effective and efficient way of doing that is irrelevant - that is what it does. |
So your 'vents' are hotter than your wing panels after a run? Mine aren't ... the double skinned wings stop anything getting out through the 'holes' in the outer skin. Land Rover Addict
Read the Clarkson column - the targets of his criticisms are the interior disco lights, the projected "Range Rover" from the puddle lamps and the silly door vents (and Gerry McGovern). The theme of it is nothing that hasn't been discussed at great length on various internet forums - the new car is too glitzy to be true to its roots and, by changing to suit the desires of tasteless people, it stops being what they wanted to buy into in the first place.
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Next time I'm working a weekend I'll get the works thermal imaging camera out and take a look at the vents, will try and take a pic with it and post my findings here. |
On my TD6 the air inlet tract sucks from the inner wing to the void between it and the outer wing and draws air from this area and can be felt when the pipe work is all attached properly. on the drivers side even though the vent is right behind the drivers side headlight. its not a massive amount but enough to feel.
That's convection. Don't forget radiation and conduction. They might not be an effective method of removing heat, but if there is a heat source behind there (and there is), some of it will be extracted via those vents. |
