Home > Technical (L322) > Won't start! What's happened? |
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 |
Yet another problem and I'm beginning to get a bit p****d off with this motor.
12th Feb 2013 5:33pm |
Thanks ebajema for the tips.
12th Feb 2013 5:48pm |
With the FFRRs (and lots of other modern cars with lots of ECUs in them) this seems to happen a lot, even small stuff done to the audio in this case can "upset" some of the other electronics. Lets hope it is nothing serious. Also check the fuses, just to be sure. MY 2010 5.0 SC Galway green and sand interior!!
12th Feb 2013 5:57pm |
Flat battery!
13th Feb 2013 3:02pm |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
Caught me out too.
13th Feb 2013 3:16pm |
I nearly bought one of those battery boosters last week and thought no, I'll never need it. Guess what's on my ebay shopping list now!
13th Feb 2013 3:21pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
you'll probably find that if the battery is over 3 years old then you might want to consider getting a new one..the fullfat is very power hungry and eats up battery's quickly.. ... - .- -.
13th Feb 2013 3:24pm |
Battery's only 2 months old Stan Cheers
13th Feb 2013 4:25pm |
that went flat quick then.. ... - .- -.
13th Feb 2013 4:28pm |
Yep. I was literally sitting in the passenger seat 20 minutes trying to upload the Intravee, the key was at 1st ignition setting so the Sat/Nav was on, but nothing else (the passenger door may have been on 1st latch so the interior light could have been on). But even so, I am still surprised it lost enough juice to prevent me from starting the engine.
13th Feb 2013 4:35pm |
i always suggest checking you have the obd cover shut as when open this apparently draws current..but with the cold weather we're having the battery was probably not 100%.. ... - .- -.
13th Feb 2013 4:39pm |
Cheers
13th Feb 2013 5:22pm |
