Home > My Range Rover > Advice please - 2011 FFRR or New Disco4
Page 2 of 3 <123>
JAYBOY
I had to have discs and pads on my RRS so i wouldn't think it was out of the ordinary.
The chap that owned may have a heavy foot.
I don't think the MY11 had Brembo's, I think they have LR own branded so they may not be as good which would lead to quicker replacements.
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #170153 4th Feb 2013 10:47pm
Pads and discs are cheap enough. I aim for about 2-3 pad sets per disc set but found a set recently so cheap I changed the lot for £120 Smile
Don't see a pm from you fella Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170154 4th Feb 2013 10:51pm
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
thanks for the info.
sorry kingpleb - meant to say to tboner that I sent him a PM. sorry about that Very Happy
Post #170158 4th Feb 2013 11:22pm
No problems fella Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170159 4th Feb 2013 11:39pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
The recall was not just for a battery change ! software update and voltage reg unit ( of some sort ) the first also changed the FBH to 15 mins rather than 30. There was / is also a software update for the 8 speed box on certain chassis numbers i am told. Far to many gone...
Post #170166 5th Feb 2013 7:27am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
There was also a recall for the battery lead mine was replaced when I had alarm problems.
Ian
Post #170171 5th Feb 2013 8:09am
Fox
It will be interesting to hear your thoughts when you have riven both.
After a FFRR I found the Disco cabin rather cramped and a bit on the cheap side.
It's not really, but the FFRR is so much better it spoils you.
Personally, if I was spending that much money I'd want something that spoiled me.
Post #170179 5th Feb 2013 8:27am
shalz
FFRR soon, fingers crossed!!!!
Hi all,
first of all, thank you everyone for all the advice and support. Amazing what brings people together.
I just put a deposit down on the FFRR.. despite a few quirks it was just incredible. The engine left me speechless. The stealer is now prepping the car under the approved used programme and getting the second service done and I should have her by the end of the month!! Cue sleepless nights until then. Very Happy Very Happy
Two things however raised some concern (and have told dealer I will only take subject to them being looked into). First, both front tyres were much more worn than the back and the outer edges were almost bald and more worn than the central part. Is this usual or a sign of a deeper problem (car has only done 22,000 miles)? Second, there were a number of small bubbles or raised round chips in the bonnet and when I tried to scratch one of them off, it came away but with a little rust in it and seemed to expose the silver body work underneath. Should I ask the dealer to respay the entire bonnet?
Fox - I did drive the FFRR and Disco 4 and you got it.spot on. I made the mistake of driving the FF first so expectations were high. I found the Disco to be much smaller and lower driving position. And although the engine seems good, it just seems to struggle at the initial push off but is fine once you are going. Weirdly (probably to do with my small size) I feel I found the disco seats to be that little more comfortable. But unfortunately I fell in love with the FF at first sight so the disco had no chance.
I'm terms of warranty, they said.it would get checked during the pre-sale inspection but they thought it had all been done and only involved replacing the battery itself and chanfing the bonnet switch. Should I take their word or insist on getting it checked again against all land rover bulletins.
Thanks again everyone!! I hope my dad loves this retirement gift..
Post #170272 5th Feb 2013 6:26pm
If it was me I'd be asking an LR bodyshop to assess it and get a new bonnet on and sprayed as it sounds like water has got under the paint and if they try and repaint it after stripping it could come back if the metal had already started to react in places Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170279 5th Feb 2013 6:46pm
shalz
thanks.
they said they still need to inspect the entire car and prep it for sale to correct any faults so i've got to give them that chance.
would this be something that would otherwise be covered under the paint warranty? otherwise I will buy subject to another dealer/bodyshop giving it the all clear.
Post #170292 5th Feb 2013 7:03pm
6yr anti corrosion warranty should cover it completely unless stone chips caused it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170294 5th Feb 2013 7:05pm
shalz
Can I insist on them replacing the bonnet?
Post #170334 5th Feb 2013 8:52pm
If it's rusting from under the paint I'd be asking for it. It would be the cheapest option otherwise they bed to strip all the paint off it, treat all the rust, flat it, prep it and paint it.. A day or two of work to do it right so worth getting an opinion from a good few local good body shops for their professional eyes on opinion Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170341 5th Feb 2013 9:08pm
shalz
Don't think I will get a chance to get independents to look at it first as the dealer is prepping from tomorrow and are based in Coventry while I'm in London.
Any thoughts on the issue with the tyres? If it may be due to suspension eBat should I be looking for damage wise?
Post #170357 5th Feb 2013 9:34pm
IanV8
My tyres were showing wear on the outer edges when I bought mine at 9,000 miles, I mentioned it and they booked the car into a specialist alignment place.
Appears OK now, 20.000 miles, but hard to tell as I am still using the same tyres.
Ian
Post #170430 6th Feb 2013 8:44am
Page 2 of 3 <123>
