Home > Technical (L322) > Brembos.... |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
yes after watching video fronts look easy.look forward to seeing your write up for rears Present :2008 TDV8 HSE
4th Feb 2013 10:35pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8517 |
http://www.fullfatrr.com/forum/post153377.html#153377 There is nothing that can't be fixed with a hammer😜😜
5th Feb 2013 7:34am |
5th Feb 2013 9:23am |
5th Feb 2013 9:25am |
Did fronts today very easy thanks guys rears look okay for the moment but will do these next week once I find my spanners Present :2008 TDV8 HSE
16th Feb 2013 3:13pm |
Quick question guys did the brakes as covered for the first time . I do have a squeak developing and believe its the rear brakes. I copper greased the rear pads on the back only hence the issue I have. Question is I can redo but where is the optimal point on the rear pads to grease around the botton where they sit into the retaining spring ?
27th Mar 2013 10:19am |
Disks look fine. Im using pagid pads. I literally only greased middle part of pad and not the anchor points at the rear which I suspect is causing the squeal.Am I right in thinking the anchor points slso need greasing at rear? Present :2008 TDV8 HSE
27th Mar 2013 6:00pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
Yes they do sir And the caliper where the pad fits in too... |
27th Mar 2013 11:06pm |
Mine are squealing now. Sounds like it may be the same thing on mine.
28th Mar 2013 7:05pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Just a quick question to throw out there to people who obviously know what they are talking about, are all FFRR 's after a certain date fitted with Brembo brakes? I have a 61 plate SE but the brake calipers have a grey finish and are marked up as Range Rover and I wondered if they are in fact Brembos in disguise or if Brembos were an option. Agueroooooooooo. 93-20
30th Mar 2013 10:04am |
I think that the calipers on the post 2010 models 4.4tsv8 and 5.0sc are still brembos but just bigger and branded RR. they use completely different pads to the 3.6tdv8 and 4.2sc. There is nothing that can't be fixed with a hammer😜😜
30th Mar 2013 4:23pm |
They are 6 piston or "6 pot" Brembo's on your car, just badged as Range Rover instead of Brembo by Land Rover... To answer your second question, they stopped fitting Brembo's on 09/10MY cars they started fitting them again in 2010... "maybe they ran out of factory stock " |
31st Mar 2013 1:16am |
