![]() | Home > In Car Electronics (L322) > iPod connection idea |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
In my 2007 Vogue SE I can easily listen to my iPod in via the Aux 3.5mm stereo socket (think only applies to SE models as the Aux inputs are for rear screens)
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
Think someone has already looked at this and found a multi-plug type connection on the back of the Aux-in panel. May be do-able, but not as straight-forward as you'd hope.
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 ![]() ![]() ![]() |
I have also done a variation on this theme by fitting an additional Aux socket in the centre console which is wired directly to the Aux input panel in the rear. I had an old griffin itrip which i use for powering the iPhone and getting the audio output from the dock connector. The aux panel can be removed by unclipping the lower plastic trim with the air vents in it and then from memory there are four screws holding the panel to the rear centre console then it just drops straight out. I did not try to splice the cable to the panel as it is a multi wire Alpine cable but instead opened the aux panel up and soldered the wires directly to the board. It all works well and got rid of the trailing wires.
