Home > Maintenance & Mods (L322) > Potential new battery type |
So, having come up against the dire lack of capacity in the standard LR battery I looked at the Bosch/Varta 020 which seems to be the de-facto standard upgrade.
4th Feb 2013 2:42pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
You could have started something with that. |
4th Feb 2013 2:52pm |
4th Feb 2013 2:54pm |
Yep, same dimensions as the 020 Bosch unit (393mm long) so was a bit of a squeeze. I do have the pyro unit on the +ve terminal as well - 07 TDV8. |
4th Feb 2013 3:30pm |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
I have Banner - Running bull (with AGM), 92ah and 850. Parked in Italy 2 weeks ago for the week, -21 and it started, no issues with the battery at all. |
4th Feb 2013 4:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35406 |
nice find Dom...let us know how it stands up to the fullfat's quirky power consumption.... ... - .- -.
4th Feb 2013 4:35pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
AGM batteries require a slightly higher charge rate. I've been reading about the 2007 alternators having a limited life. Is this a concern? i.e. is the 2007 alternator up to it? The CTEK battery charger rate for AGM batteries is 14.7v. Normal is 14.4v 2012 5.0L S/C
4th Feb 2013 4:47pm |
The Denso alternator is well known for high charge voltages. It is also infinitely re-buildable as I have personally found out. Biggest issue with TDV8 alternators is getting them off the car. That's what is commonly known as a Pig of a job.
4th Feb 2013 4:59pm |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 |
I don't mean to put the cat among the pigeons, but why not get;
4th Feb 2013 6:45pm |
'Cos some of us store the removeable towbar in the cubby where the 2nd battery would be. |
4th Feb 2013 8:34pm |
Will the tow bar not fit in with the spare wheel? |
5th Feb 2013 8:26pm |
Might do, but not in the official storage thingy. Would need to be wrapped in an old towel or something but there's not a lot of room in mine there either. I already keep a set of jump leads, a properly heavy duty towrope, a 2 foot breaker bar with 22mm socket (wheel nuts), a discovery-3 bottle jack and handle, and a 12v tyre compressor
6th Feb 2013 9:07am |
Thats what the space behind the back seats is for Stops it rattling around and is much easier to get to
6th Feb 2013 9:12am |
