Home > Technical (L322) > Fuel Gauge stopped working?
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
........then it started again, stopped, started and stopped again Shocked (over a couple of days)
Currently still not working but every now and then it will display the correct level of fuel for 5 or 10 minutes then off again! This has been going on for the past couple of weeks Sad
Before I get the stealer to investigate at hundreds of pounds per hour as I'm now out of warranty Big Cry anyone have an idea of what maybe causing it? I think electrical as it doesn't display an incorrect level, it's either correct or not working!
I know there is a TSB for the 2010MY RRS but not sure if this extends to a FFRR Rolling Eyes
Help!
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #169603 2nd Feb 2013 6:39pm
You should be able to get a meter on the wires coming from the sender to check it. You will need to find out where they are but that's your first move I would think. Previously..
Post #169605 2nd Feb 2013 6:46pm
Ajay(UK)
On the couple of occasions I have asked for help rather than offered it the response both times hase been......well somewhat limited Big Cry
I guess the lesson here is that the search option is so good that when I can't find the answer is because no one really knows!
I booked it in with the stealer last Monday and for the past 6 days its has been working fine and then today for no apparent reason it's packed up again Evil or Very Mad Good job I didn't cancel the appointment this Friday so for the benefit of others and the search facility I will post the solution when known! Shocked
Post #171390 10th Feb 2013 8:37pm
Googsy
Same thing happened mine although it was only faulty for about 3 days then corrected itself. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #171394 10th Feb 2013 9:29pm
reading through other fuel problems it could be the battery, low voltage possibly... ... - .- -.
Post #171399 10th Feb 2013 9:51pm
RR2008HSE
Well, a big thank you to you, and all those that do post answers and info. It's much appreciated. Very Happy
I've always found gas gauges very reliable in all the cars I've ever driven. It made me annoyed when learning to fly that the tank and fuel level needed to be inspected and verified every time before taking off. Finally hearing about a faulty gas gauge makes the task seem less annoying now. Bow down good luck!
Post #171412 11th Feb 2013 12:03am
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
Having just dealt with fuel pump problems I know that the two right hand wires as you look down on the connector from the back of the car are for the pump motor it's self. They only show a current when actually cranking the engine.
The other wires must be the two senders inside the tank but I cannot imagine testing for a current will help if your problem is intermittent.
Like Stan said first check the battery.
Good luck. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #171418 11th Feb 2013 5:26am
STEV8
England 2005 Range Rover Autobiography 4.4 V8 Java Black
This is normal, no?
One minute you`ve got half a tank of fuel,couple of hours later it reads empty.... Rolling with laughter Rolling with laughter Thumbs Up 05`V8 AUTOBIOGRAPHY
Post #171435 11th Feb 2013 9:49am
Ajay(UK)
I've just had a battery recall so it can't be my shiny new gel style battery Whistle
It definitely has to be some kind of electrical issue as again today it stopped and started again for about 10 minutes and then stopped again. Appreciate the comment about using fuel but you cannot go from empty to half a tank to empty again in 10 minutes even in a FFRR Laughing
It will probably be working fine again by Friday with "no fault found" but give us a hundred quid for looking Evil or Very Mad
Reality is it will most likely end up being a dodgy fuel sender unit but there is no real easy way to check Sad
Post #171556 11th Feb 2013 7:32pm
Not without removing it and checking the resistance, if that is even how they work these days. There is nothing that can't be fixed with a hammer😜😜
Post #171558 11th Feb 2013 7:46pm
Freddie The Fish
United Kingdom 2011 Range Rover SE 4.4 V8 Fuji White
Did you find a fix for this, mine randomly shows empty then springs into life again ?
Post #435217 17th Apr 2017 5:20pm
It's a replace sender units job I'm afraid. There is nothing that can't be fixed with a hammer😜😜
Post #435218 17th Apr 2017 5:42pm
GGDR
There was a guy who posted that the whole fuel pump unit inc sender was a BMW unit (could be correct for a circa 06 but not much later) and that he bought a non original replacement for a very reasonable price.
Would be a very simple job if swapping the whole thing out.
But check the resistance first as NMJ said.
Access pretty easy under the rear seat carpet. Cheers, Greg
Post #435220 17th Apr 2017 5:56pm
GGDR
Try here: http://www.fullfatrr.com/forum/topic41996....l+pump+bmw
and/or
http://www.fullfatrr.com/forum/topic21385....l+pump+bmw Cheers, Greg
Post #435225 17th Apr 2017 6:03pm
