Home > In Car Electronics (L322) > NO AUDIO -HELP!
STEV8
England 2005 Range Rover Autobiography 4.4 V8 Java Black
NO AUDIO -HELP!
hi guys.wondered if anyone can help.got in ffrr today and no audio at all.screen ok and every thing else seems normal except no sound.cd visually plays and radio.its as if volume is turned off.any simple checks i can do tommorrow before having to visit indie??is there a connector or fuse a novice like me can check?? Sad Thumbs Up 05`V8 AUTOBIOGRAPHY
Post #169203 31st Jan 2013 7:55pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
It might be nothing but why dont you disconnect the battery for 20 minutes and see if it resets itself, its worth a try Idea gone fishin'
Post #169210 31st Jan 2013 8:30pm
it'll all work tomorrow...the fullfats like that, it taunts you.. Laughing ... - .- -.
Post #169214 31st Jan 2013 8:46pm
+1 for disconnecting the battery as a starter. Thumbs Up
Post #169215 31st Jan 2013 8:49pm
bluearmy
England 2006 Range Rover Vogue 4.4 V8 Java Black
had this problem left overnight everything was fine the day after Very Happy
Post #169217 31st Jan 2013 9:09pm
STEV8
and the award goes to STAN.....10 out of 10.i should have known better really.got in this morning and all back to normal-classic ffrr behaviour.think i will check for water ingress still though because it did coincide with rain pi Censored Censored ing down all day.must be her time of the month or something..... Thumbs Up 05`V8 AUTOBIOGRAPHY
Post #169274 1st Feb 2013 9:40am
Bow down to me peasants...... Mr. Green
seriously though, this kinda thing happens if you dont properly start the range, ie if the key is turned for a few seconds and key taken out and then started again..i dont think the ecu's get the full voltage then when you start proper, they are in a shut down mode...i found this with the lcd screen not coming on... ... - .- -.
Post #169284 1st Feb 2013 10:06am
STEV8
Good advise STAN.Me thinks this will not be the last i will hear of this... 05`V8 AUTOBIOGRAPHY
Post #169298 1st Feb 2013 10:49am
do check for water ingress though , that might be the root of the problem.. ... - .- -.
Post #169299 1st Feb 2013 10:52am
max
Italy 2007 Range Rover Vogue TDV8 Buckingham Blue
it happened yesterday to me : this morning a piece of cake...
may be my FF wants some silence, sometime.
probably is thinking what fault invent tomorrow : fantasy needs silence
max 2007 L322 TDV8 3.6 vogue
1981 Alfa Romeo Spider 1600
Post #285189 9th Oct 2014 9:09am
Weegie
If you leave it till the system shuts down (about 20 minutes) it will often restart. John
GAP iiD BT-Sold
Post #285192 9th Oct 2014 9:41am
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
This happened to me a few weeks ago, i unplugged the 3 plugs to the amp and re-fitted them, it burst into life and has been faultless ever since........
Post #285316 9th Oct 2014 6:50pm
