Home > Technical (L322) > Turn OFF Touch Screen Display
Real RR
I prefer to drive with the TSD switched off and particularly at night. However every time the car is started the display turns itself on again. Its a real pain continually having to turn it off manually maybe a dozen times a day. Is there a way to disable it from turning on at all until requested?
Post #16753 16th Apr 2010 1:48pm
Pull the fuse? Rolling with laughter Discovery 4 HSE
Post #16757 16th Apr 2010 3:15pm
Shaun the Sheep
England 2007 Range Rover Vogue TDV8 Stornoway Grey
Just press the voice control and say "display off" if only the Mrs was so easy to operate Rolling with laughter
Post #16759 16th Apr 2010 3:25pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Yes, the best way to do it, is via the voice command.
I also like to use it off at night, it's too bright....
The newer cars (2010+) have a quick button to turn them off, I think. I remember seeing a button to do that, I think it's the one that replaced the audio settings.
Post #16762 16th Apr 2010 3:45pm
