![]() | Home > Maintenance & Mods (L322) > Sorry - another LED and canbus issue! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
did you turn the bulb around in the socket, it night be a polarity problem.. ... - .- -.
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Yes Stan, tried that. The approach lamps do illuminate (so must be the right way round) but only for about a second or less, then the go out. About the same length of time as an indicator flash when you lock it. |
faulty bulb maybe [just guessing now] ... - .- -.
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
There is a full thread on this and iirc a solution has yet to be found in terms of an LED bulb.
Tried that too |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Um, try fitting a resistor (or one to each side) ? .
@Dave - sorry, my "tried that" was in response to Stan!
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
Cappo send me a pm if you would like some that work and are very bright,
