Home > Maintenance & Mods (L322) > ZF5HP24 Fluid Drain and Filter Change....by Saint.v8
all comments here re Saints.v8 excellent 'how to'...
http://www.fullfatrr.com/forum/topic16149.html
in wiki... ... - .- -.
Post #166365 21st Jan 2013 7:04pm
klf400
excellent write up Thumbs Up
it is a bit messy, i have the luxury of a 4 post lift but the constant dripping when the sump is off is a bit of a pain and is difficult not to get some oil on yourself
i note the colour of the fluid which was the same as mine { 95000 miles ] , to date i have changed my fluid 3 times as you cant empty the torque convertor , my fluid is a lot cleaner but its certainly not the colour of the new fluid going in 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #166374 21st Jan 2013 7:36pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Just to add one thing, once you have drained the sump put the plug back in and run the car for a few seconds, do this a couple of times and you will prob get another litre out of the box, if you have no apparent leaks measure how much came out and this is roughly what needs to go back in. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #166376 21st Jan 2013 8:03pm
That was a truly excellent technical thread! Bow down
I'm used to changing oil in my 110's and Series gearboxes, so am used to the messy bit. Never changed oil in an auto before and was always perturbed by disconnecting the selector mechanism.
I do believe your write-up has reinstated my confidence. Thumbs Up Si. <This is my name.
Post #166386 21st Jan 2013 8:30pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
excellent write up sir and great how to for reference,
I might have a go at this myself having read that,last 2 times I got a specialist to do it but they certainly know how to charge for it over here in Eire.
Excellent work Thumbs Up
Post #166471 22nd Jan 2013 11:10am
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
nice service, are interesting also any blue you used, where to be found?
Post #166511 22nd Jan 2013 2:09pm
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Many thanks for your kind responses....with the cost of garages nowadays it makes sense to try these things ourselves....and I am glad it helps others to save some cash...!!
Post #166593 22nd Jan 2013 6:49pm
Saint.v8
Sorry Madcima, I am not sure I understand your question....maybe you could rephrase it please?
Post #166594 22nd Jan 2013 6:51pm
madcima
I'm sorry, basically, I want to buy those ramps blue as you used, I wanted to know where I could find it
Post #166616 22nd Jan 2013 7:59pm
Saint.v8
The Ramps I got from a company in the UK called Machinemart...
Can be had from the bay of e or a local Auto Factors mine cost £50 a pair.
Post #166618 22nd Jan 2013 8:01pm
daveo
another great write up, you should change your name to ,Haynes Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #166623 22nd Jan 2013 8:21pm
I was a bit worried about those ramps, what weight rating do they have? Per axle / per ramp ? .
Post #166636 22nd Jan 2013 8:43pm
madcima
are crw25 or cr2?
Post #166640 22nd Jan 2013 8:54pm
Saint.v8
CRw25 and are rated at 2.5 tonnes a pair (1.25 tonnes each)
L322 Weight with driver and full tank 2570kg
Post #166671 22nd Jan 2013 9:50pm
