Home > Technical (L322) > 2010 Problems....
Page 2 of 3 <123>
Vogue
Mick, 1791 allows you to enter sat nav details and destinations etc on the move. It only works with some vehicles though incl Disco 3 and Sporty's - depends upon which version of the sat nav disc you have installed... and I think LR disabled this feature for the 07 MY as it didn't work anymore
Post #16602 14th Apr 2010 1:27pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
OK 753 - TV/DVD in motion, step by step (2010 - but 2006 etc similar)
Start up DVD/Select TV Channel WHILE STATIONARY. Follow previous instructions to get the DIAG PIN screen up :
Brings you to this screen (2006-2010 slightly different) :
Press Video Input Test :
Select TV/DVD Button :
Pictures showing vehicle in DRIVE, TV on display and E-Brake off :
Please note : TV reception awful in works carpark!!!
All other options are worth checking out too Thumbs Up
Post #16604 14th Apr 2010 2:01pm
dantheman
I tried, but can't seem to get to work - no hidden menu. Or am I just being a bit thick?!? Shocked
Post #16608 14th Apr 2010 3:49pm
DMRR
Make sure you are on the "home" screen, i.e. the one with the options for NAV, PHONE, AUDIO etc, very top middle press finger to screen, hold for 5-10 secs, then push the HARD NAV key - not the touchscreen one, until the DIAG PIN screen pops up Very Happy
Post #16610 14th Apr 2010 3:57pm
Vogue
dantheman think this might only work on 2010's
Post #16620 14th Apr 2010 4:15pm
DMRR
It worked 100% in my 2006 FFRR 4.2SC - that's how I knew how to do it Laughing
Post #16626 14th Apr 2010 5:09pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
It works on MY2007+ at least.
Now, ''Thrasher'', I can't give you that as a hack. The 1791 is hack but this one is not.
This is just a way to enter a place where you can test most of the MOST systems. You're not really watching TV but just testing the connection.
Either way, it works 100%. I also love the rear view on the move, and also the vehicle signals where you can see the battery voltage, the amount of dimming in the screen and instrument binnacle. Perfect...
Give us some more of those codes and/or ''hacks''.
Post #16633 14th Apr 2010 6:14pm
I can get the Same as what Thrasher has described, just dont think i tried it with the TV on Embarassed and its the 06 SC i have Menu slightly different tho .... Thumbs Up ====================================
Post #16637 14th Apr 2010 7:20pm
dantheman
I have the first of the 06MY facelift: tried as described Thrasher - still no joy. Rolling Eyes
Post #16649 14th Apr 2010 9:22pm
Got it working while driving but i take it you have to go thru the procedure all the time when you switch the ignition off as it don't seem to store the settings ........ ====================================
Post #16683 15th Apr 2010 12:16pm
DMRR
Just like all the codes, none stay after ignition off.
Anyone interested in any other codes?
Post #16684 15th Apr 2010 12:26pm
Thumbs Up Great tip tho .... Thumbs Up Thumbs Up Thumbs Up Bow down ====================================
Post #16685 15th Apr 2010 12:35pm
VMPP
Yes please.
You could even make a list of the ones you know and what they do.
Post #16686 15th Apr 2010 1:03pm
DMRR
I will assume most people know the 1791 hack? Anyway, if not, hit the "home" button for the nav screen (2006-NOT 2010) so you get the menu with dest entry etc, press top middle of screen until Pin pad appears - enter 753 here and you get all the sat nav diags.
Please note - after playing in here you need to power down vehicle for 5-10 mins before control is restored to normal touch screen activities!
Post #16687 15th Apr 2010 1:34pm
nbunney
Thrasher
Have to put my hand up, but what is the 1791 hack?
Post #16692 15th Apr 2010 4:39pm
Page 2 of 3 <123>
