Home > Technical (L322) > Fuel Pump In the tank TD6 |
m90got Member Since: 18 Oct 2011 Location: scunthorpe Posts: 120 |
Has anyone had the diesel tank fuel pump fail, if so what were the symptoms , im having trouble with a fuel injection system fault and my indie thinks this is the problem, Current Stable:
17th Jan 2013 3:33pm |
Had mine go!
17th Jan 2013 4:26pm |
Thanks for help lads fingers x this works beginning to wish I had never bought it !! Current Stable:
17th Jan 2013 5:17pm |
madcima Member Since: 25 Oct 2011 Location: Italia Posts: 137 |
hi you can do two tests
17th Jan 2013 7:29pm |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
The tank is quite easy to access. Removing the back seat is about the hardest bit as it is so damn heavy, but after that, fairly straight forward. There are inspection covers in the floor, remove these then there is an inspection plate on one side of the tank, and the plumbing and electrics in the plate on the other side. Undo the plug and hose clamps, then slide the hoses of the barbs - this is a bit fiddly, but once off, the plate, pipes and pump come straight out. The pump is then easy to change on the bench. If you have a few basic tools and a couple of hours, give it a go. Cheers - Gav. |
18th Jan 2013 11:09am |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
I had my in tank fuel pump replaced on my TD6 just before xmas.
18th Jan 2013 9:17pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I had rough running and would not rev over around 1800rpm and assumed it was an injector or fuel pump, but it turned out to be the fuel injector wiring loom that had failed (independent loom that just plugs into the rest of the electrical circuit). Turned out to be a relatively cheap part in the end @£58 + vat if I recall which didn't seem bad for the item I was getting. Steve
19th Jan 2013 1:35am |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Hmmm, I wonder if this is what is up with mine.
19th Jan 2013 6:48am |
When my loom failed , I got no warning messages at all, the car just ran very rough (I was about 20 miles into a 60mile trip home when it happened so I nursed it home). Steve
19th Jan 2013 12:05pm |
