Home > In Car Electronics (L322) > Ignition switch live wire!!
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Hi guys I've bought an after marker dvb tuner for the 2004 non touch screen!
Prob is I can't seem to find a ignition live wire around in the sat nav amp dsp area!!
Plenty of permanent live wire but none that switch off with the ignition??
I've done a quick search on here with no luck!
Could anyone point me in the right direction? Colour wire etc!
Thanks in advance
Post #165204 16th Jan 2013 6:01pm
i'd get a multimeter and check all the spare plugs around that area, you should find something.. ... - .- -.
Post #165221 16th Jan 2013 6:52pm
SATVC
I've been in there poking around with a test light but most lives seem to be permanently on?
Ill prob spend some more time at the weekend!
Thanks
Post #165227 16th Jan 2013 7:07pm
There is one. You might need to remove the black tray to get better access.
There is a part of the wiring loom with a big black connector that runs over/in front of the radio. In there (you'll have to unpick it) there is a purple wire. That's your ignition live.
See here for more info and a picture!:
http://www.fullfatrr.com/forum/post96346.html#96346 .
Post #165310 16th Jan 2013 11:03pm
SATVC
That exactly what I needed to know! Thanks mate!
Oh been reading your car pc threads! Looks like an epic install!
Post #165311 16th Jan 2013 11:05pm
Should be even better now I have my AUX-IN sorted Thumbs Up .
Post #165314 16th Jan 2013 11:08pm
SATVC
That takes car electrics to a different level! lol
Thankfully with this dvb unit I bought it has extra inputs so with a bit of luck ill get my ipod connected!! Through the tv aux? It'll be mono but hey hoo!
Post #165318 16th Jan 2013 11:14pm
