Home > Maintenance & Mods (L322) > Drop Link Replacement Now Squeaking |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Think it may be my ARB bushes .... May get some silicone spray and dose it up or perhaps loosen them then retighten. |
8th Jan 2013 12:29pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35247 |
are these the ones that have to be tightened fully when on the ground so the weight of the fullfat puts the bushes in the correct position.. ... - .- -.
8th Jan 2013 12:42pm |
They were genuine LR ones from duckworths, fitted them with wheels still fitted and on ground but suspension in high mode, may try to losen and retighten while at standard height. |
8th Jan 2013 1:48pm |
I suggest to take a bit of Molykote grease, thin it with mineral oil (machine oil) and use a syringe to get it into the bushes. I am going to do the same on mine. Molykote (MoS2) goes into the metal surface matrix and lasts very long with super low friction. MY 2010 5.0 SC Galway green and sand interior!!
8th Jan 2013 2:17pm |
Thanks for the advice .... May give that a go. |
8th Jan 2013 2:23pm |
Strange thing - the squeaking only appears after driving a few miles now. |
9th Jan 2013 12:08am |
Removed and refitted links today with some copperslip on faces, also silicone sprayed bushes and no change - still squeaking after a few miles .... Think it must be ARB bushes .... Can car be driven without the links fitted to test if this is the case? |
9th Jan 2013 12:16pm |
must be frustrating trying to find that squeak...not sure re driving without the links though.. ... - .- -.
9th Jan 2013 12:42pm |
