![]() | Home > In Car Electronics (L322) > Labels |
1. Navi Unit
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 ![]() ![]() ![]() |
Joe, you did an amazing post on your system but you lost me quite quickly, thanks for labelling my system. I am about to send my BM54 to Baris but I thought the BM54 was the radio and amp? Is there an additional power amp as well? The cable seems to head up to the rear top corner of the space so I would guess it is attached to an aerial, maybe for a phone? I'm really not sure. 2002 Vogue Epsom Green with Ivory Leather.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
2 is the DSP digital sound processor which in all the manuals and tech docs seems to be called an amp.
Cheers mjdronfield
Crickey - how similar are our car histories ? !! 2011 Range Rover Vogue SE 4.4 TDV8
I know. I didn't mention my fist car which was a chevette but I then had a MK 1 Fiesta sport 2002 Vogue Epsom Green with Ivory Leather.
Yes, you should have DSP on the screen. Its just a fancy equaliser really plus concert hall and stuff 2011 Range Rover Vogue SE 4.4 TDV8
I didn't notice it was called DSP but I do have the graphic equaliser.
I have that "power amp" / DSP, no sub woofer and nothing about DSP onscreen, just straight forward bass/treble/bal. My inner wheel arch cover does have a "soft bit" for speaker sound to pass through. Wonder if some b its are missing? .
I think the HSE has a different setup in standard trim. Will have to do some research as to what the options were. 2011 Range Rover Vogue SE 4.4 TDV8
my HSE is not standard ( |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
the only items my hse was missing was heated steering wheel ,heated rear seats and a sunroof, had everything else.. ... - .- -.
Yeh, thats why I put "In standard trim" because I've a feeling yours wasn't standard, and had a few options.
Burgers84 Member Since: 17 Aug 2017 Location: Macclesfield Posts: 1 ![]() ![]() ![]() |
Paulhh did you send your unit to baris, how did it perform? |
