![]() | Home > General > Are the diesel Range Rovers any good? |
aneurysm1 Member Since: 12 Dec 2012 Location: burnley Posts: 202 ![]() ![]() |
If the economy and performance was the same then i would chose a petrol wthout a shadow of a doubt, they are smoother and quieter!
Well I previously had the SC 4.2 and changed to TDV8 not for any reason other than I got fed up spending most of my time filling it up at garages ..... Would I go back to a petrol more than likely |
IF the economy and cost per litre was the same i would swap for an SC but thats it. Low down grunt and lazy cruising is what mine does mostly and when offroad I can put it in Low Range and it will put itself up quite a steep gradient with ease in 2/3 |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
[quote="RR2008HSE"]
Agree with Mick 100%. Diesel is Satan's urine. I run a TDV8 but before this I had a petrol V8 Disco-3. Most days I wish I'd kept it. Sadly LR don't make the D4 with the petrol engine for the UK market or I'd have one in a flash. |
^^^ My thoughts too Dom spill some diesel on yourself and the clothes are shagged , step in some |
I would never consider a diesel if the economics weren't a lot better (over here there are no diesel FFRRs either). The only thing could be range, as in if I would be doing an overland trip through Africa with it. Diesels just go a lot further and with some extra jerrycans you can get very far, on petrol that is a bit of an issue.
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Mine is a 2002 Vogue TD6 with 145k Miles
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
Like Mick I went from an SC to a 3.6 TDV8, and the only thing I find mildy irritating is the diesel noise and ocassional smell, other than that, I find I drive the TDV8 more and probably faster than the SC, because the SC just drinks petrol when it's used "properly"!
In a garage why not just park with the pump on the passenger side of the vehicle and watch where you walk? Then use the plastic gloves?? Or just avoid the garages |
Yeah, all this tosh about getting diesel on your shoes and clothes, piece of bloody nonsense! |
^^^ Maybe in the ar5e end of Jockistan. Attended service is long gone from everywhere I've been in the last 10 years.
Diesel and petrol pumps are on same stands so makes no odds!
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Thanks for all the input! Much appreciated. |
