Home > Technical (L322) > Sat Nav - is it rubbish??? |
Kilovolt Member Since: 07 Feb 2010 Location: Derbyshire Posts: 104 |
The sat nav breaks it neck to use motorways as a priority and then A roads next in-line. There is a setting to avoid motorways (completley) but this is often not helpful either - you end up in people's back gardens almost.
5th Apr 2010 7:01pm |
elbitrevnoc Member Since: 17 Mar 2010 Location: Berkshire Posts: 150 |
Hmmm... appreciate the point about local knowledge and I don't expect sat nav to choose any clever 'rat-runs' that a user may know, but the A419 is hardly a back road - it's almost entirely dual carriageway and is always selected by any other sat nav that I've used. It's also a shorter route by some 42 miles, so the sat nav was trying to take me on a route that was 66% further than it needed to be!!! As for trying to head me towards North Wales by leaving Reading and heading east on the M4 the mind boggles!!
5th Apr 2010 7:35pm |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 |
Out of interest, what year is your car? Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD! |
5th Apr 2010 10:26pm |
It's a '56, with touchscreen system. Haven't checked what disk is in there yet though. |
5th Apr 2010 11:20pm |
Use it as a guide, but don't rely on it 100% if you know better.
6th Apr 2010 9:34am |
doublejay Member Since: 08 Nov 2009 Posts: 131 |
SO i have an 05 prefacelift but with touchscreen nav......will that be cd or dvd based ? |
10th Apr 2010 9:35pm |
I assume that all touch screen sat nav will be DVD-based. You should find a single DVD-ROM drive inside the rear n/s panel.
10th Apr 2010 11:34pm |
RREIRE Member Since: 22 Jan 2010 Location: Cork Posts: 78 |
I have the same model as you have it is DVD based. |
11th Apr 2010 7:58pm |
Real RR Member Since: 13 Aug 2009 Location: In a Defender Posts: 33 |
I leave mine switched off and use a portable stuck to the windscreen. Makes for an interesting comparison if you have them both running at the same time. |
16th Apr 2010 2:40pm |
