Home > Technical (L322) > My first air suspension fault !!
Page 1 of 3 123>
Just got home after a crappy day fixing my sons central heating and other plumbing faults. My wife then tells me she started the car and heard a hissing noise, so switched it off.
I have just been out to look. The car looks level. I started it, 10 seconds later a loud hiss for 3 seconds came from behind the offside wheel. I got out, closed the door, and a few seconds later the blast of air came again for about 3 seconds. It sounds like a hose is off hopefully and not a bag split. I would have thought if it was the bag the car would have sunk.
I'll investigate tomorrow but any thoughts?? Previously..
Post #160616 30th Dec 2012 9:12pm
ebajema
I have heard of hoses coming off the airbags (even on the forum). My bags were recently changed and it looks to me the hoses are relatively easy to do. The hoses are the "standard" plastic air hoses you see in industrial automation with the brass nut connection.
Could also be a leak in the hose or at the compressor. Good luck hunting for the problem. MY 2010 5.0 SC Galway green and sand interior!!
Post #160618 30th Dec 2012 9:20pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Sounds like it could be the air line going from the air compressor to the air tank. i think this hose goes through the off side wheel arch to the tank. it would prob start hissing when the compressor starts up to top the tank up. as you say, if it was the air spring then it would probably have dropped in that corner. also the hose to the air spring i would imagine would let it drop aswell. if its a standard size hard plastic pipe you get straight joining connectors that are just a push fit. these are used for the airlines on hgv's. you may be able to cut the burst bit out and use one to join the pipe back together again. would save having to replace the whole pipe. think i might have some lying around. would have to check the size though. if you ain't too far from me you 're welcome to one if you like. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #160630 30th Dec 2012 9:59pm
I am looking forward to checking tomorrow. Thanks for the offer wats39. Hopefully it is something easy as the weather is not brilliant for pulling a car to bits! Previously..
Post #160636 30th Dec 2012 10:09pm
wats39
Aye, theres nothing worse than having to work on a car in the p Censored ing rain. these things cant happen when its braw an warm an dry outside which makes fixing things more enjoyable. have fun Very Happy '04 td6 se
Post #160647 30th Dec 2012 10:32pm
Aye, theres nothing worse than having to lie on your back to work on a car in the p Censored ing rain Whistle Whistle
Post #160671 31st Dec 2012 12:03am
You're right... Gonna build a new garage ! Laughing Whistle Previously..
Post #160673 31st Dec 2012 12:13am
Best do it soon before you're too old then Laughing Laughing Laughing
Post #160681 31st Dec 2012 12:49am
Laughing Seriously, we have cleared a bit of ground at the front and we are going to build a garage fit for a FFRR. Well, that's the plan. I just have to come up with a design, get it approved at planning etc etc...
Anyway, I hope tomorrow is dry.. Laughing Previously..
Post #160683 31st Dec 2012 12:55am
Sorry but it's going to be chucking it down tomorrow, sunshine on Tuesday though, but you'll be too hung over to do anything Whistle
Post #160684 31st Dec 2012 1:00am
Nicka2311
Scotland 2005 Range Rover Vogue Td6 Java Black
I may only be 27 but I don't remember having this weather at all to work on cars outside? What happened to this Global warming we were promised?
Post #160763 31st Dec 2012 1:25pm
its a bag of tosh thats what Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160769 31st Dec 2012 1:42pm
Too busy today to look at the car... I will go easy on the juice tonight and get in aboot it tomorrow..
Have a good evening gentlemen and a happy new year when it comes.. Thumbs Up Previously..
Post #160858 31st Dec 2012 6:38pm
I guess that since you went easy on the juice last night and signed off at an early 3:30am you are now lying on your back underneath the FFRR sorting it out Laughing Laughing Laughing
Post #160964 1st Jan 2013 1:48pm
Haha... Correct... Just found it. There is a plastic connector that has come apart. I just came in to get the camera to take photos... So GIRFUY... Laughing pics to follow... Previously..
Post #160965 1st Jan 2013 2:04pm
Page 1 of 3 123>
