![]() | Home > Technical (L322) > SAT NAV ON GOLF COURSE !!!!! |
Probably the little heard of SANTA V effect, swirling after effect vortexes from 24th |
Probably the little heard of SANTA V effect, swirling after effect electro magnetic vortexes from 24th |
You got a touch of googsy2itus as well then Joe � |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
boys boys settle down and HELP,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35507 ![]() ![]() |
try that Sal or a battery reset.. ... - .- -.
thanky you stan,
Could be the SAT NAV aerial/receiver had one go on similar Jag unit recently and then SAT NAV only works on dead reckoning. The Jag one was in the tailgate spoiler and got killed by water ingress. Simple replacement fix. |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
There should be an option in the menu to reset/recalibrate position - also there is an option there for resetting it after a tyre change. |
Yes but if it needs recalibrating there will be a reason.... |
Thank you guys will check it over
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
My sat nav said I was on a golf course once .... but unfortunately it was right. Serves them right for not letting me turn around in their car park when I got lost ....
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7870 ![]() ![]() ![]() |
Excellent.
![]() ![]() ![]() Spewed coffee on my keyboard... ![]() ![]() Salb, I don't have much experience with the later Satnavs, but if this was a pre-touchscreen I would immediately concur with Gaz - bad GPS antenna (or antenna cable/connector). ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
