Home > Maintenance & Mods (L322) > Soundproofed my boot (part 1)
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
If you were LPG you could fit some fake cats and there is no emissions test Wink One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #160816 31st Dec 2012 4:13pm
Don't even need a fake cat if you just point to the back box they cant complain as the smog test is all that matters on the LPG test but you need to have it showing on your V5 which also gets a road tax reduction as well and possibly something in the congestion zone. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160820 31st Dec 2012 4:17pm
JohnnyDangerous
I think your wrong there as after a certain year all cars have to have a cat fitted even if they can go thru an emissions test without one and all LPG cars fire up on petrol (even though the cat wont be hot enough to work) might be wrong though Big Cry My MOT station when i asked (my cats are gutted) wanted to know if it 'appeared' to have cats fitted, I also know of one guy who had a prohibition put on his car by VOSA because it was catless and needed one due to year of manufacture. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #160823 31st Dec 2012 4:24pm
It used to be the case that a car simply had to pass an emissions test as part of the mot. Manufacturers fitted cats to allow their products to pass the emissions test.
If cars could pass the emissions test without a cat so be it.
Things changed at the begining of this year, 2012, in that the new Mot Inspection Manual requires all spark ignition engined cars fitted with a cat at manufacture now have to be fitted with a cat at test, no cat fitted the car fails.
This is even if the car passes the emissions test without a cat.
Diesels don't require cats to be fitted, at present, they just have to pass a smoke test as before.
Post #160826 31st Dec 2012 4:40pm
Lloyd Barnes
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Sad really as its easy enough to get even big petrol V8s through emissions tests without cats if they are not overly worn and properly tuned (Ive seen it done with dinosaur carburettor technology, FI engines are easier) Lloyd Barnes
Current
Crendon 427 Sideoiler Cobra in build... 7 litres of madness!
Gone
2008 TDV8 Vogue - Black with Ivory/Grand Black Lacquer
2008 VW Touareg 3.0Tdi
6.3litre Dax Cobra - 12.34 Second 1/4mile at 114mph Smile
Post #161197 2nd Jan 2013 11:54am
