Home > Off Topic - Other Cars > TD5 towing V L322 |
Fame Member Since: 01 Dec 2012 Location: Oliveira do Hospital Posts: 42 |
Had to deliver 2 big horses to the Vets in Aveiro . Trailer was Ifor Williams HB510 towed with Defender TD 5. On arriving , I had to turn into a narrow gateway, from a very narrow country road. My clearance was a couple of centimetres on each side.I did manage to rub the rubber strips around the trailer's light fittings at the rear but got in and out with some difficulty.The main problem was the Defender's very limited turning circle ( 7.60 tyre size )
14th Dec 2012 2:42pm |
Its going to be fatter.
14th Dec 2012 3:58pm |
90
14th Dec 2012 4:00pm |
FFRR turning circle is $hite |
14th Dec 2012 4:01pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Not as bad as the Defender tho' Graham
14th Dec 2012 4:58pm |
MORC? Would like to see the video's!
14th Dec 2012 5:10pm |
[quote="kingpleb"]Its going to be fatter.
14th Dec 2012 5:47pm |
Thanks, the "outer pillar" technique sounds logical to me-- going to use this approach when collecting them. Range Rover Vogue TD6 2002
30th Dec 2012 12:51am |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 |
The range rover will be a 100 times easier to manoeuvre a trailer with. I've towed trailers/caravans with both 90/110 defenders ,td5 discovers and range rovers. The worst being the discovery |
30th Dec 2012 8:54am |
Thanks Brian,
30th Dec 2012 10:13pm |
I had a discovery 2 facelift 7 seater with the air suspension on the rear and it was a terrible tow car. Unless you turn in or remove the steering stops the turning circle is a joke. What I found with the air suspension the trailer would snake unless the trailer was loaded 100% perfect. |
30th Dec 2012 10:17pm |
