Home > Technical (L322) > Any experience of windscreen fitters?
Hi Guys,
Hope you are all having a good festive period
Just wondering if anyone has any experience of having a new windscream fitted by and of the national windscreen co.s
I have a large crack developing in mine, from a barely visible stone chip. Complete pita.
On the upside, quite a few of the heating wires had stoppes working.
Probably going to give autoglass a call but windering if there are any better fitters out there. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #160416 29th Dec 2012 4:59pm
Not covered by insurance?
Just be there when they come to do it:
Make sure they know exactly which model your vehicle is and that they have the right screen (auto dim mirror / heated screen)
Have they fitted one to a FFRR before?
Do they know how to remove the rear view mirror and wire up the heated screen bits?
How will they tackle the A pillar covers (on mine they drilled out the existing rivets and fitted with new)?
Do they have all the sealing bits to go with it (top, sides, scuttle)?
You can test the heated screen with clingfilm before they leave......
National Windscreen guys did mine, took them a good couple of hours on a dry day, only downside was a stone chip I picked up 2 weeks later and the heated screen is like a zebra on a frosty morning (seems as if another element goes pop every time I use it) ! .
Post #160423 29th Dec 2012 5:51pm
As above but make sure its a genuine one if possible as others have noted problems with non OE ones.
Also make sure the top trim is put back as well because if it not fitted right it makes a lovely noise at speed Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160425 29th Dec 2012 5:56pm
bizzybus
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Autoglass put wrong glass (plane instead of tinted) in my jag last year also damaged paint on roof so keep an eye on them if you use them Wink (SEE WHAT HAPPENS WITH HEATED SEATS)
Post #160429 29th Dec 2012 6:06pm
Cheers for the replies guys, it is covered on the insurance, and having luckily
Read the small print, i have called autoglass.
Aparently i have no choice, swiftcover will only pay out if you use them, if you dont they will only pay out ฃ100.
Lucky i checked.
The lady on the phone checked it against the vin of the car so she got the right one. Wasnt in stock but will be available for fitting at home on monday. last time autoglass did one on my skoda they bought the wrong screen. Big Cry
I will be here when they do it so hopefully they will do a good job. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #160432 29th Dec 2012 6:16pm
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
I had auto glass do mine a few months ago no problems what so ever great service really pleased F**K IT you only live once
Post #160438 29th Dec 2012 7:10pm
Windscreen Dave
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
If you have any problems give me a shout as I fit quite a few ffrr windscreens due to the amount of farmers around here.
Post #160450 29th Dec 2012 9:10pm
hongkongphooey
Isle Of Man
I recently had a new screen fitted by Autoglass in Preston. I took the car to them as it was a Censored day.
I'd called them before hand and told them of the existing spec and that I wanted a pilkington glass screen.
Can't fault them, no mess whatsoever, quiet as an Angels fart and everything working as it should.
I guess I found a good fitter!
Best of luck.
Phooey.
Post #160479 29th Dec 2012 11:15pm
looks like Censored weather tomorrow, so im going to give the derby branch a ring and see if i can drop it off. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #160597 30th Dec 2012 8:47pm
In the end I took the car to them and left it, I asked what screen would go in and the fitter said it would be an OE spec one not a Splintex.
Any how have just collected it, all seems fine and dandy. I suspected that it had had a screen before as the wipers were mis aligned, he said it had, and had put the wipers back in the correct place. They have fitted a Pilkington screen which is great, and i have noticed that the wires for the heater seem thinner. The have fitted new trim clips and plastic rivets to the A pillar trims.
All in all it looks to be a top notch job. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #160831 31st Dec 2012 6:00pm
hongkongphooey
Isle Of Man
Brilliant.
Now go and get drunk! Very Happy
Post #160882 31st Dec 2012 8:23pm
Already fully under control. Thumbs Up Thud There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #160885 31st Dec 2012 8:26pm
hongkongphooey
Isle Of Man
Nice!
Happy New Year, Thumbs Up
Post #160892 31st Dec 2012 8:34pm
poworoy
England 2008 Range Rover Vogue TDV8 Galway Green
Just about to have a replacement screen fitted - can you advise how you test with clingfilm?
Post #187025 7th May 2013 12:42pm
put clingfilm on screen, switch on heated screen, watch clingfilm shrivel up..do both sides.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO ฦŽ๊“•โˆ€๊“•O๊“ค PICS
Post #187029 7th May 2013 12:58pm
