Home > General > Security alert! (Do you know who's waiting for you at home?)
Dolphinboy
Without being alarmist, suggest we all look at this link and just think next time we get into our comfort zone on the drive home.. We always think this only ever happens to other people ..... Until it doesn't! This happened to someone I know (not this case) and has had an alarming effect on them -pls, Lock your doors when driving at all times and stay safe!
http://www.dailymail.co.uk/news/article-22...Rover.html
Ps I know this happened after the owner got out of the car but there are ways to counter this too. Pm me if you need to know more. (I'm sure Noddy et al could also give guidance if required.)
Post #160370 29th Dec 2012 1:22am
Good call DB, it's always a worry and part of the reason i don't like my wife driving mine on her own... OK mine is alittle more extravagant than most FF's (due to the business) which maybe makes it worse!
Craig Thumbs Up
Post #160372 29th Dec 2012 1:36am
My favourite FFRR feature, from a safety/security viewpoint, is the auto lock after hitting 10mph.
Hacks me off that my daughter can't lock herself into her Ford Ka before driving off. .
Post #160373 29th Dec 2012 2:02am
Joe, fit an aftermarket alarm with SSL (speed sence locking)
Post #160374 29th Dec 2012 2:16am
oliver9627
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I have a 2004 4.4 v8 vogue, my car does not lock when driving unless I press the button. Is it meant to lock automatically when moving over 10mph. If it does any ideas what the fault may be? Gone:
Golf GT TDI 150- Still got.
BMW 325TD
Range Rover Classic
Defender 90
Post #160375 29th Dec 2012 7:35am
It's an option that needs turning on in the ccf to enable. I've just got into the habit that as soon as my door or the last door close the button is pushed Smile
Along these lines its a reason why you should never drive into a parking space but reverse into one. If anything happens you can drive forward much more quickly and safely than you can reverse. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160381 29th Dec 2012 9:40am
Won't work, is manual locking only by key. Only way is to get in, wind window down, lock door with key etc. Big Cry
Unless you are doing the weekly shop at the supermarket! Smile .
Post #160387 29th Dec 2012 10:07am
Still do it then joe Smile towbars make people leave a decent amout of room most of the time and those that don't suffer the consequences Wink usually my weekly shop goes in the passenger footwell or in the rear footwell between my tools as well Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160389 29th Dec 2012 10:09am
TugRR
Very angry watching the video - "muscular build" it says, yet it takes two of the cowards hiding behind their balaclavas - what a pair of pussies Rolling Eyes
Thumbs Up Where do you go after one of these . . . ?
Post #160393 29th Dec 2012 11:14am
Dolphinboy
Just to clarify, the best defence is awareness of who or what is going on around you. If the bad guys see you doing even the most basic awareness drills, they will leave you alone and look for an easier target.
Your most vulnerable points are at home and at work. you must be alert to suspicious people in the vicinity of your home and at work. Look for people or cars not usually there. Check out of your house windows before leaving. Alter your timings if you can and also your route.
Before you get in your car, see if there is anyone near - walk past your car if necessary and then walk back when you are happy. Never bleep your opening key until you are at the door and ready to get in straight away. Lock your door ASAP.
These are the most basic means of staying one step ahead. Also, in traffic, always ensure you can see the rear wheels of the car in front. This means you will have enough space to pull away and around them if necessary.
A lot of this is common sense but over time you build up an awareness of what's not right. Hope this helps.
Post #160404 29th Dec 2012 12:31pm
Don Henshall
United Kingdom 2014 Range Rover Autobiography SDV8 Carpathian Grey
Be aware sure but let's not get to paranoid FFS Thumbs Up 718 GT4
FFRR AB
BMW R1250RT
Honda ST 1100
Sold
Freelander 2
Porsche C4S Cab
D4
BMW 520 M Sport Touring
BMW R1200RT
BMW R1150RT
MX5 2lt Roadster
Post #160415 29th Dec 2012 2:31pm
oliver9627
Kingpleb,
whats is the ccf? Also how do i turn the automatic locking on so they lock once the speed is over 10mph.
Do I need a IID tool? I know someone with a snap on computer tool. Gone:
BMW 325TD
Range Rover Classic
Defender 90
Post #160419 29th Dec 2012 4:27pm
supermario
Terrible stuff - need to get this as option
Post #160421 29th Dec 2012 4:51pm
CCF is the Car Configuration File.
Need one of the below to edit it
IID
Faultmate
Autologic.
T4/IDS/SDD from Landrover could likely do it but will not let you play directly with the ccf Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160424 29th Dec 2012 4:54pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Prob far more chance of winning the lottery than this happening to someone, bit like those nutters preparing for the end of the world! On the other hand I love a tear up so if someone wants the car bring it on !!!! One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #160506 30th Dec 2012 12:45am
