Home > Technical (L322) > Voltage Question
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Voltage Question
Just driven the car over 7 miles, when we got to the other end I did the onboard diagnostics and the voltage reads 11.8V on the digital dash display, now I dont see how this can be correct as the car turns over very fast and it would be flat after driving with lights and demisters on etc so my question is can the voltage at the bat be say 12.5 static and more after a run but wherever it takes its reading from (terminal R) lower, ie a bad cable. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #158520 19th Dec 2012 4:42pm
simon1233
I'd check the battery with a multimeter, the on-board diagnostics are not great for voltages IMHO. Check with a multimeter both with the engine running and with it off. With the engine going (idling) you should see about 13.5-14 volts and without the resting voltage should be around 12.6 volts (for a fully charged battery), 12.3 volts would normally indicate only a 50% charge in the battery for example.
Post #158529 19th Dec 2012 5:48pm
JohnnyDangerous
Hopefully my bear will be down tonight with the verdict and a multimeter so we can check it. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #158530 19th Dec 2012 6:06pm
If I do the secret menu voltage check it seams read 1v under engine off or on . 2008 MY Supercharged
Post #158531 19th Dec 2012 6:07pm
^^^^ I agree, need a good voltmeter. Thumbs Up
14.0V at the battery with the engine running at about 2000rpm.
12.6V at the battery a few hours after a run with nothing other than the engine switched on.
Post #158532 19th Dec 2012 6:07pm
JohnnyDangerous
That would be about right then but 12.4 is a bit low, also at night you can see the display getting brighter if you rev the car. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #158535 19th Dec 2012 6:15pm
JohnnyDangerous
Via diagnostic machine it was 13.8-14v @2000rpm when switched off 11.9v One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #158635 20th Dec 2012 1:33am
last time i checked mine it was 14.5v on idle and 12.4 when switched off, maybe your battery is on the way out.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #158657 20th Dec 2012 10:13am
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
I hadn't realised that 12.4v would be too low when measuring the battery with everything off? I thought anything over 12v would be good. Maybe I need a new battery?
Post #160187 27th Dec 2012 7:03pm
If I don't use my car for a few days the voltage drops to 12.4V and stays there.
Car starts no problem.
LR indicate a requirement of 12.5V on the battery in the electrical manual.
0.1V below that is neither here nor there.
It'll change by that much when it's cold.
Post #160212 27th Dec 2012 9:08pm
