Home > General > Whilst driving the FF round a Roundabout
landrover have probably done a little bit of research in what pressures are the best for the fullfat so i would go with the figures in the manual... ... - .- -.
Post #159809 24th Dec 2012 12:43pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
I cannot believe anyone will notice the difference between 50 and 55 series tires, never in a million years will that effect the handling of a car like the RR, my winter wheels used to have big 285/50/18 tires and i barely noticed the difference from 275/40/20. It still went round corners the same and no handling dramas at all.
The symptomes seem more like another thread I put up about instability when someone said turn the dsc off and on a lock give it some welly and it will try and lift a wheel, Either that or your roundabout has diesel on it. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159817 24th Dec 2012 1:05pm
I'm now running mine on the 19" with wrangler HP all weather tyres, as I tend to drive around with piles of Censored In the car at all times, I have the pressures set at 2.5 bar font and 2.9 rear, which seems fine.
I had a problem where my nuts had come loose. Made the handling a bit dicky, so may be worth giving them a tweak Mick. There is nothing that can't be fixed with a hammer😜😜
Post #159963 24th Dec 2012 10:21pm
