Home > Technical (L322) > Engine light and judder
simon1233
Sounds to me like the symptoms I had on my RRSport when the EGR valves failed - this would also light up your engine management light as the valve(s) will report that they are no longer working properly. You need to plug into a diagnostic machine to accurately identify the fault - do you have friendly local garage who will help you out today?
Post #159796 24th Dec 2012 11:34am
To clear out injectors sometimes its best to take the filter cover off for the fuel filter after draining a little out, and then shoving all the injector cleaner you can get in there and the rest in the tank Smile
Simons advice is sound though that if you have someone local with a hawkeye or the like clear all your faults and then do some live scanning Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #159799 24th Dec 2012 11:39am
supermario
Thanks so much guys. Ill drive down from manc to London tommorrow my father in law has a friend with a garage so hopefully take it there on 27th. I'm a AA member but hopefully won't use them I tried to get it to a lr garage today but all closed
Post #159811 24th Dec 2012 12:49pm
have a safe journey.. Thumbs Up ... - .- -.
Post #159812 24th Dec 2012 12:55pm
supermario
Thanks guys once again - got it checked out it was the mass air flow meter! Although I have just received a call saying they have some other errors Sad and they are investigating.
Post #161500 3rd Jan 2013 10:39am
supermario
Hey guys,
Just incase anyone gets similar symptoms the issues were fixed and were:
- Faulty Mass air flow meter.
- Faulty inlet Manifold tuning valve.
Post #163721 11th Jan 2013 2:58pm
proser
Hi Supermario,
do you have part number for the Inlet Manifold tuning valve ??
Got fault code indicating this but unable to work out where it is. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #372931 18th Feb 2016 11:55am
