Home > Maintenance & Mods (L322) > Sticky door |
if i know that there is going to be a cold snap overnight , to prevent the door from sticking before i lock it up for the night i just run a dry microfibre cloth around the door seal and around the internal frame of the door.
7th Dec 2008 6:07pm |
kin Member Since: 20 Nov 2008 Location: rainy city Posts: 348 |
Thanks Mick |
7th Dec 2008 6:22pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
you can also wipe the seals with a cloth that has something like WD40 or maybe even Vaseline jelly as it also helps the water proofing and keeps the rubber supple. Discovery 4 HSE
8th Dec 2008 9:42am |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 |
Food grade silicone lubricant is a good "winterisation" trick to do at the start of winter. It stops the stickiness, but also doesn't poison you if you get it on your (or your kids) hands. Also washes out if you get it on your clothes (and doesn't stink!). -
8th Dec 2008 10:05am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3748 |
turn on the FBH 15 to 30 minutes before I leave |
8th Dec 2008 10:06am |
Robert_it Member Since: 13 Oct 2008 Location: Bergamo Posts: 27 |
In the Aircraft industries where planes go to like minus 50 Deg C and temperatures can vary 70 Deg C within an hour only Silicon compound is used for "winterisation" in various form depending on surface and size.
8th Dec 2008 11:25am |
You might struggle if it was like this though.....
8th Dec 2008 12:55pm |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 |
I have seen this image and others. They are fantastic. I beleive they were taken from one of the Lakes in Switzerland but cant remember which one. |
8th Dec 2008 3:29pm |
Thanks guys, I'll use the silicon spray then, it'll also keep the rubber supple |
8th Dec 2008 10:14pm |
