![]() | Home > LPG > Noisy Pump |
alz4321 Member Since: 09 Dec 2012 Location: Wales Posts: 18 ![]() ![]() |
Pump ? Mine doesn't have an lpg pump. The only pump in the wheel well on mine is the compressor for the air suspension. |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
It is the EAS compressor, mine is noisey as well, could be its reverberating on something where its been moved from the spare wheel well. LPG systems wont have a pump they just work off pressure in the tank. One day your life will flash before your eyes......................................make sure yours is worth watching!
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 ![]() ![]() ![]() |
Thanks for that. Must be the suspension pump. Maybe should be mounted on rubber? |
oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51 ![]() ![]() ![]() |
It will be the air suspension pump. I am on LPG and mine has been moved. I can hear my pump very clearly when working. Gone:
Tallsaj Member Since: 23 Aug 2013 Location: Birmingham Posts: 75 ![]() ![]() ![]() |
Hi I have 2005 55 plate sc vogue had LPG fitted but the pump making a lot of noise, it's just sitying above the LPG rang at the mo with bubble wrap and it's not in it's toitoise case?? |
Hi I am new to the forum. Recently had my range converted to LPG its a Brc system my pump is noisy it's has twin tanks its sitting just above the LPG tank. It's still noisy any one found a good place for it no noise or vibrating?? |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
most good conversions place the suspension compressor in the Offside cubbyhole and there is a special mount made by one of the larger manufacturers expressly for this purpose. with a bit of sound attenuation it's not too bad - and it only goes off if you change height |
