Home > Maintenance & Mods (L322) > Cost to get drivers leather seat repaired
ollielloyd
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Every seat looks as new apart from drivers which is worn and slightly torn on edge as you get out.
Anyone know what the cost of getting this repaired is?
Post #159178 22nd Dec 2012 1:48am
Shouldnt be too much, the best bet is to find a local trimmer in the yellow pages and get a quote. Will be a lot less than a new base Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #159181 22nd Dec 2012 8:00am
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
What colour is it? I have re connolised mine from sand to black but noticed that covers on E.bay are not that expensive, the bases are around £40 I believe. Tip....... if you go that route buy a new seat foam and the seat will feel like new. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159193 22nd Dec 2012 9:39am
ollielloyd
New cover could be good idea. It's sand colour i think.
Ill have a look.
Post #159213 22nd Dec 2012 1:11pm
Search the bay then as they often come up in the lighter colours. darker ones not so often and especially not the drivers side Sad Would be nice if Overfinch actually let us know how much they would charger for the ones they take off for their trims to be put on... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #159214 22nd Dec 2012 1:26pm
http://www.ebay.co.uk/itm/Range-rover-L322...5899f800ca
http://www.ebay.co.uk/itm/RANGE-ROVER-VOGU...3cbdf159e6
http://www.ebay.co.uk/itm/RANGE-ROVER-VOGU...3cbdf169bd
http://www.ebay.co.uk/itm/Range-rover-L322...589956f53a
Could slowly get the bits and do the whole trim Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #159216 22nd Dec 2012 1:35pm
mzplcg
The main issue with your idea Will is that the driver's one will always be knackered. I've been looking for ages now so I can replace mine.
The seat foam is about 40 quid plus the usual from Dan, but the new leather base cover was about 370 plus vat.
I am talking to a local trimmer about getting some new bases made for the fronts although he reckons the passenger side will be fine if re-connolised. Driver's side is all stretched though as you might expect after 95k miles. Even over a new foam it looks tired and creased.
If anyone comes across the right answer to this then I'm all ears.
Dom.
Post #159219 22nd Dec 2012 2:10pm
JohnnyDangerous
Ive seen bases and backs really cheap on ebay, only the black ones are more expensive but still under £100. If you buy new seat cover the seat will then look new like the rest. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159222 22nd Dec 2012 3:06pm
Iirc that the drivers and pasenger bases are the same.
It can be a bit hit and miss on the bay.
Has to be right colour, piping, heated/not heated, right style for the seat, add all the variables together and your chances of finding one which is right is quite small. Might be one out there though, ive been looking on and off for a heated jet with jet piping, with heat for a 2008 vogue non perforated, for a while to replace mine when it gets too shabby. No luck yet.
Maybe in the new year Whistle There is nothing that can't be fixed with a hammer😜😜
Post #159229 22nd Dec 2012 4:11pm
JohnnyDangerous
Then you still have to strip the seat and all its wiring and and get it all to fit, I stripped mine right back and changed colour from sand to black and fitted 2011 leather front door panels and changed the dash pad etc, flocked all the trim in the boot in black and the rear shelf. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159231 22nd Dec 2012 4:20pm
JohnnyDangerous
Also Im pretty sure the heater element is seperate to cover in the base of the seat which is prob the worn part. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159232 22nd Dec 2012 4:24pm
I think the heater element was part of the seat cover on early cars and became separate later on...... There is nothing that can't be fixed with a hammer😜😜
Post #159236 22nd Dec 2012 5:04pm
JohnnyDangerous
Mines 2002 and pretty sure it was seperate. Its in a tissue like material. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159242 22nd Dec 2012 5:38pm
according to microcat, the seat heating is serviced as part of the seat cover to vin 6A999999 from 7A > its available as a separate item, thats not to say its not removable on earlier seats, just not available separately i think........ There is nothing that can't be fixed with a hammer😜😜
Post #159249 22nd Dec 2012 5:48pm
