Home > Maintenance & Mods (L322) > 06 facelift headlight washers |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Do you really need them for the mot? They were not standard on your model year. Previously..
19th Dec 2012 7:50pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8620 |
Just looked in the MOT instruction manual, it not clear on this point, its along the lines of,
19th Dec 2012 8:27pm |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 |
As far as i know. i think if they are HID or xenon lights they must have a washer fitted. mine were originally halogen headlights so wouldnt have needed them. |
19th Dec 2012 8:29pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
what wires did you join..and what head light was they behind..for starters the lights have to be on and then it will wash on the 6th pull of the windscreen washer.
19th Dec 2012 10:31pm |
Hi Daveo, joined the brown/black and the black/yellow together on the passenger side as per a post on here. the headlights were on and the pump works fine as tried the connection for the windscreen pump on it. would the headlight washers not work on the 1st wash then miss a few times? looking at the iid tool specs there is a headlight wash/wipe setting in the body control module so thinking it may be turned off. iid tool is on the to get list but have to sort the pixels on the to do list 1st maybe just take a feed from the windscreen washer pump to switch a relay for the headlight washers to get through mot until i can fix it properly. |
19th Dec 2012 11:32pm |
i have to do my washers, it went through the mot with them not working but he never checked them, did you take the front bumper of to put the washer bottle in.. V8 facelift Range Rover Autobiography 22" wheels.
19th Dec 2012 11:51pm |
No didnt take the bumper off. the plastic splash guard in the wheelarch is all you need to take off. that is providing the hoses to the headlight washers are on and going to or near the washer bottle already. just two bolts holding the bottle in then and thats it, simple enough. |
20th Dec 2012 6:05pm |
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 |
to get them to work as they normally would you need to find the black with yellow tracer and black with brown tracer on the nearside that hasnt been used after the headlight upgrade (would have been in the original headlight multiplug) , join these two wires together and providing the washers are piped up and the pump is wired they will work how they did before the conversion. |
20th Dec 2012 9:31pm |
Dont think there were any extra wires at the headlight plug. 2 for each bulb, (a power and an earth) so 8 in total. i did find two wires of the colour you mentioned at the headlight wiper connector though and this is what i joined. u sure its the headlight multiplug and not the headlight 'wiper' multiplug the wires are at? |
20th Dec 2012 10:54pm |
brain fade moment, i just checked again and your right it is the wiper plug. |
21st Dec 2012 7:56pm |
Thanks for checking that Arron. was beginning to think i had wires missing that means it must just need activated in the bcm then. i hope. will update the results when i get it done. '04 td6 se
21st Dec 2012 8:24pm |
