Home > Technical (L322) > No central locking or electric windows
muffster
2002 Range Rover Vogue Td6 Java Black
Hi folks.
I've just had the passenger side door mirror off (2002 TD6). When i put the door card back on, no power to mirror, electric window doesn't work and the central locking on this door doesn't work.
Is it just one of the plugs that i havn't clipped back on properly? Possibly the largest black one, does this supply power to the various functions of the door?
Also, is there an online manual somewhere, i'd like t find out what all the various plugs actually do.
many thanks.
Muffster.
Post #96100 4th Dec 2011 3:39pm
probably the connectors ...
Post #96118 4th Dec 2011 5:50pm
muffster
Hello again folks. I've been trying to suss out this problem, now got the window working but the central locking does not work only on this door. It worked perfectly before i had the card off and i havn't done anything with the lock mechansim. All fuses are ok.
It appears that there is no power to the central locking motor but i can't tell why. Could it be coincedental that the motor has packed in or have i done something wrong.
There is no power to the mirror either.
Any offers on this please.
Many thanks.
Muffster
Post #98474 20th Dec 2011 1:08pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Sounds like a problem with the part of the loom that feeds that area. Did you possibly pinch some cables when you were working on that part of your car, or alternatively a connector has worked loose somewhere along the loom. Sounds too much of a coincidence to me. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #98476 20th Dec 2011 1:14pm
try a battery dis-connect/re-connect...procedure is on the forum.. ... - .- -.
Post #98477 20th Dec 2011 1:14pm
muffster
Thanks for the speedy response.
When i look at it again i will try the plug which goes to the motor.
Am i right in assuming i shoud get a 12volt pulse at the plug to operate the motor when i lock the car with the key?
Will also try a battery re-connection.
Cheers.
Muffster.
Post #98479 20th Dec 2011 1:24pm
muffster
Quick update:
Been out in it today and now the passenger side window is not working!!
Any ideas whats going on??
Cheers.
Muffster.
Post #98953 22nd Dec 2011 6:58pm
nikbarber
United Kingdom 2006 Range Rover Vogue SE Td6 Zambezi Silver
Hu Muffster,
Did you ever get this sorted? I am getting the same symptoms on my driver's door.
Thanks,
Nik. 2005 FFRR Td6 Vogue
1991 Defender 90 200Tdi
Post #156192 8th Dec 2012 9:03pm
mick79
2004 Range Rover Vogue 4.4 V8 Java Black
Check out my post hope it helps http://www.fullfatrr.com/forum/topic14906.html Owner of a bottomless pit, Sorry i mean range rover l322.
Post #156219 8th Dec 2012 11:22pm
nikbarber
Thanks for the reply. I tried disconnecting the battery and giving it a good charge. I thought that disconnecting it for a while might reset all of the ECU's. Unfortunately it hasn't, and the faults are still there despite having a fully charged battery. 2005 FFRR Td6 Vogue
Post #156580 10th Dec 2012 9:10pm
muffster
Hi mate.
My problem was with the connectors.
Despite the fact that i had checked them 3 times previously, on the last attempt the electrics came back into life.
i can only assume it was a poor connection.
Post #156597 10th Dec 2012 10:00pm
nikbarber
Thanks for the tip - it turned out to be the white connector on the switch pack (C2058) which is the one that connects to the BCU and the central locking motors. Even though the connector was latched shut, it wasn't inserted into the socket all the way. All sorted now! 2005 FFRR Td6 Vogue
Post #158492 19th Dec 2012 12:40pm
muffster
Great nice one!
Post #158900 20th Dec 2012 9:35pm
