Home > For Sale & Wanted > For Sale: Front Brembo Brakes unused
festival-of-speed
I have for sale a set of new and unused front Brembo calipers, Brembo discs, Brembo pads and associated pad retaining kit for Full size Range Rover L322 (02-on).
I bought these to upgrade my Discovery 3 as I was needing to replace all discs and pads anyway having been told they would fit. They do not. As such, they DO NOT FIT Range Rover Sport, Discovery 3 or 4.
I have since purchased the correct Brembo brakes for my D3 and all is well - incredible stopping power and they look awesome......anyway, I digress.
As such, I have some surplus brakes for FFRR - my wife hopes to buy a TDV8 this year, but will have these fitted already.
I don't mean to teach granny how to suck eggs, but I understand the following to be correct:-
The mounting holes on these calipers are specific to the L322 Range Rover (Series 3) when fitted with 19" wheels. I understand that 18" wheels will not clear the larger diameter discs and calipers.
These calipers can be used to replace and upgrade standard front brakes on L322 Range Rover as found on TDV8 and Supercharged models. No modification or cutting is required as these are genuine Land Rover parts. The calipers replace the standard caliper carriers and utilise the same mounting points on the steering knuckle. The only additional upgrade I think is required would be larger dust sheilds mounted on the hub to clear the larger discs (this is what I had to do on my D3).
The calipers are matt grey anodised models as found on the TDV8 Range Rover, not the gloss black finish. The calipers have a few light storage marks (as can be seen in the images included) but are unused and are as new. The discs and pads are new and unused too. I have already fitted the pads and retaining kit to the calipers (I was about to fit them to my D3).
If you are needing to replace your discs and pads, and/or want to increase the braking power of your 3 tonne Range Rover (not to mention improve the looks) this is the cheapest way you will be able to achieve such an upgrade as individually and direct from Land Rover, these parts are pretty expensive.
The calipers are marked with the following numbers:
Right Hand Caliper:- 08M191 177 (stamped/etched); 20.8653.02 1A (cast)
Left Hand Caliper:- 08M191 021 (stamped/etched); 20.8653.01 1A (cast)
The discs are marked with the following numbers:
Disc #1:- LAND ROVER SDB500193 MIN TH 27mm 5508SDD8G BREMBO (stamped); 3H42-1027-AA (barcode sticker)
Disc #2:- LAND ROVER SDB500193 MIN TH 27mm 5508TDD8H BREMBO (stamped); 3H42-1027-AA (barcode sticker)
No warrantee given or implied.
If you would like to see some more images, I have the brakes on ebay - my user name is festival-of speed as it is here.
£450.00 for whole set. A courier can be arranged and would be charged at cost - collection could be arranged too.
I think I've covered everything, however, if you have any further questions, please do not hesitate to email me.
Thanks,
Ross
[img]http://www.fullfatrr.com/gallery/displayimage.php?album=lastup&cat=10533&pos=0[img][/img] Currently D3 owner!! Wife wants a FFRR S/C.
Post #15722 26th Mar 2010 1:25pm
On a related subject my TDV8 Brembos are the silver/grey version and are in need of tidying up. Can these be painted gloss Black/Yellow/Red with an appropriate Brake paint and would you recommend and undercoat plus paint or spray????? (I am not a painter Confused )
Post #15723 26th Mar 2010 1:59pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
Gaz try RTEC - I am sure they sell a kit there for the boy race brigade which may be fine for the Brembos
Post #15730 26th Mar 2010 3:48pm
Thanks the Kits is here http://www.rtecshop.com/?p=product_view&product_id=2321
I think I will look in Halfords first...
Many thanks Gaz
Post #15731 26th Mar 2010 3:56pm
Full fat not diet
Brembo Stickers are on EBay for that pro look once painted!
Heres one i found
http://cgi.ebay.co.uk/Brembo-brake-Decal-S...2eabc5398d
Post #15732 26th Mar 2010 4:00pm
Duly "Watched" thank you.
Looking at that I might just do them in Red!
Post #15737 26th Mar 2010 4:35pm
Full fat not diet
If you are going to paint them then Red is best IMO Thumbs Up
Post #15863 28th Mar 2010 3:22pm
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Saw a set of these at Brock on Saturday and there bloody huge!!!!
Glws..... If I had the cash right now is be buying these from you! TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #15877 28th Mar 2010 6:33pm
