Home > Technical (L322) > manual gear change
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
manual gear change
any one help
my gear box drives changes gear and everything it is suposed to in auto mode but will not change to manual it carries on as normal in auto when the gear leaver is pushed to manual. also the display on the dash does not change from D
could this be some kind of switch failure or do i fear the worst, as i say no lost gears in auto
any ideas or has some one seen the fault before
thanks all Bow down 02 Range Rover HSE Zambezie silver 4.4
Post #15834 27th Mar 2010 11:09pm
GKP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Cairns Blue
Once you've moved the gearlever over to lthe left ('Sport' mode) are you then nudging the lever forward and backward to change gears up and down? Not sure you should be reading this bit.
Post #15848 28th Mar 2010 10:06am
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Sounds like something is out of adjustment, or a switch/sensor has gone up the swanny. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #15853 28th Mar 2010 12:12pm
StevieH
It will stay in 'D' until you select a gear...try and move lever forward and back like a tiptronic
Post #15870 28th Mar 2010 4:17pm
andyw
thanks all
i do move the lever as though i was changing however nothing actualy does change Sad
i am inclined to think that a sensor is duffed is there one to detect the leaver in sport mode and then the up and down sensors take over ?
thanks 02 Range Rover HSE Zambezie silver 4.4
Post #15879 28th Mar 2010 6:46pm
jayzee
On your year and model, when you flick it into sport mode the green D stays lit on the dash. The LCD should say "sport mode", and when you toggle back and forwards, the gear numbers light up on the green display.
If nothing is happening, it does sound like an alignment problem with the linkage or a sensor issue - nothing too expensive... I hope Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #15883 28th Mar 2010 7:54pm
andyw
off to the indie tommorrow then thanks all Thumbs Up 02 Range Rover HSE Zambezie silver 4.4
Post #15884 28th Mar 2010 7:58pm
