Home > Technical (L322) > Gearbox about to go?
andrew-a
Lately i have noticed that when i am cruising at between 50-60mph at 2000 revs, and i then want to accelerate, there seems to be an initial hesitation, without any movement on the rev counter. When you then press the accelerator harder, it drops gear and the revs climb and it accelerates.
i don't know if this is normal but i don't seem to remember it doing this before and i have had the car for over 1 year. I was concerned if its the early signs of gearbox failure or slipping clutch (not sure if that applies to automatics.. Question )
2003 Vogue 4.4 petrol
Any help would be appreciated.
Post #158473 19th Dec 2012 12:12pm
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
had a similar problem in the summer....
did a fluid change..all good since free use of "RSW" all comms to anyone nearby
Post #158478 19th Dec 2012 1:00pm
andrew-a
It was serviced this time last year and i am sure that the gearbox oil was changed...but i will double check
Post #158480 19th Dec 2012 1:03pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Sure it's the gearbox? Could be the engine not responding to the throttle - MAF could be on its way out.
Post #158481 19th Dec 2012 1:04pm
andrew-a
I haven't got a clue what it could be, just like i dont know what a MAF is! Smile
Post #158482 19th Dec 2012 1:08pm
Simes
Mass Air-Flow sensor - in the induction pipe from the air filter. If they pack up, they don't seem to cause a fault code, but the engine starts running rough - i.e. acceleration can be a bit all or nothing for example.
Post #158483 19th Dec 2012 1:09pm
hoppy
dont know of any garage that does a gearbox fluid change as part of a service free use of "RSW" all comms to anyone nearby
Post #158484 19th Dec 2012 1:12pm
andrew-a
that sounds likely - thanks
how much are they to replace?
Post #158486 19th Dec 2012 1:15pm
Simes
http://www.ebay.co.uk/itm/Range-Rover-L322...0841421748
About £45!
Post #158487 19th Dec 2012 1:17pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I had similar issues and it was cleared by a single flush of fluid and a filter change on the gearbox. A double flush might change more oil, but it costs a lot more and isn't always necessary. The Megaflush guy wasn't very accommodating, although I'm not convinced by the Megaflush process anyway.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #158497 19th Dec 2012 1:56pm
