Home > Off Topic > Change signal bars on iphone to dBm D3/4 forum Rip
Discotres wrote:
P.S. Just tried this on Android and it works as well!
If anyone is in a poor signal area they will know that the signal bars on the iphone are not pretty accurate, well to help get a better picture of what is going on you can display the dBm in place of the bars, the lower the number to zero the better.
Here are the instructions, it is fully reversible, it may help some:
Step 1: Dial *3001#12345#* on your iPhone then press Call.
Step 2: You'll now enter Field Test mode. You'll notice a signal strength indicator on the upper left hand corner of your screen. You can toggle between signal strength bars and a number by simply taping on it. At this point, press the home button to exit the app or if you would like the feature to be permanent, continue on. Don't worry, the process is completely reversible.
Step 3: Hold down on the Power button until you see the ‘slide to power off' bar. Do not power off the device.
Step 4: Press down on the Home button until the app closes and you return to your home screen.
That's it. Even when restarting the iPhone, the signal strength can be toggled between bars and numbers. The closer your number is to zero, the stronger your signal is.
The lower your number, the stronger your signal—but don't include the - sign when evaluating (so, if the signal says -60, that's better than -90).
To return to the default bars permanently, follow these steps:
Step 2: Press on your Home Button once.
Works a treat Smile
PS do at your own risk as well as there are other bits to play with in there! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #157996 17th Dec 2012 11:40am
title says iphone, post says android? ... - .- -.
Post #157998 17th Dec 2012 11:42am
just re-read the grammer.... Embarassed ... - .- -.
Post #158000 17th Dec 2012 11:43am
cool it works - i wont tell it my 13 year old son ... Twisted Evil All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #158003 17th Dec 2012 11:50am
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
I'm tempted but will wait for a few more guinea pigs first Razz
Post #158219 17th Dec 2012 10:54pm
Works okay on mine , anyone went into the other fields that are showing Whistle Whistle
Post #158221 17th Dec 2012 10:58pm
Doing so now Mick Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #158225 17th Dec 2012 11:13pm
Andy
Can't get it to work on my mates Galaxy S2?
Post #158273 18th Dec 2012 11:42am
Laughing Laughing Laughing "My Mates Galaxy S2" Like it Noddy experiment on someone else's phone Bow down
Post #158275 18th Dec 2012 11:45am
The other bits just give you info and don't allow modification as its an engineer menu. used to be popular on Nokia a lot. used by engineers once repaired to ensure signal strength is consistent with known working phones at the repair centre Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #158287 18th Dec 2012 1:08pm
