![]() | Home > Technical (L322) > Battery Woes.... |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 ![]() ![]() ![]() |
I struggled and definitely thought it would never fit - it did - I just hope I never need to take it out.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8672 ![]() ![]() ![]() |
I got it in the tray, couldnt seem to move it over far enough to fit the pyro module in as well though. |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
I have the MY08 with the pyrotechnic charge and, as has been said, it does fit - but only after you have skinned all of your knuckles in the process of pursuading the b****r to go in.
Obviously didnt try hard enough......... |
Oh what an interesting life I lead.
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Div is a bit harsh but the S5 does fit, eventually, so I will let you decide whether you own personal insult is fair |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
A lot of 'wiggling' is required, but it does fit (just), my positive terminal with the pyrotechnic charge seems a little high on the positive post but it is securely attached, might try Ajay's technique of lifting the negative end up as I have tried pry bars of various lengths in the past... |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Has anyone tried the Optima batterys as advertised in LRO etc ? |
After a bit of hunting around whilst out and about to see what sort of deal i could get on a Varta battery, i have concluded that with the discount at ECP the S5 Bosch battery is an absolute steal. Over the counter £150 seemed to be the going rate for a 110Ah battery.
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 ![]() ![]() ![]() |
This is the 110Ah Varta battery here - for under £100 delivered.....
got the Bosch into my 08 its a tight fit but it goes in eventually .... sounds familiar |
I still have the 90ah s3 in, but it doesnt like the fbh, after running the fbh for 15 mins it was ever so slightly slow to turn over.
If you check out ecp, they have an exude 100 amp/hour battery which should just slot in as the battery is the same physical dimensions as the standard |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 ![]() ![]() |
I have had a lot of issues with my battery this year. TD6.
