Home > Maintenance & Mods (L322) > Fitting Battery Brain, electrical question |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Have you considered a battery drain back thro the alternator when the car is not being used? |
13th Dec 2012 2:50pm |
user58101 Member Since: 13 May 2012 Location: London Posts: 11 |
I haven't tested for a battery drain back to the alternator when the car is switched off.
13th Dec 2012 3:37pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Does this (battery Brain) only kick in after all the systems (e.g. DVD / Airbags) have shut down? .
13th Dec 2012 3:45pm |
The Battery Brain only kicks in if it finds that the battery voltage has dropped below 11.8V.
13th Dec 2012 4:00pm |
Battery drain back thro the alternator starts as soon as the alternator stops rotating. It will occur in addition to any other current drains that may be present irrespective of the "sleep" condition of the car. |
13th Dec 2012 4:03pm |
roger 47 Member Since: 24 Aug 2012 Location: Exmoor Somerset Posts: 80 |
Correct me if I'm wrong.
13th Dec 2012 4:56pm |
Roger 47 - I think you're correct. However, this is unlikely to happen after driving the car.
13th Dec 2012 5:13pm |
I agree abrownson if you have a good battery and an alternator delivering the correct output.
13th Dec 2012 5:27pm |
If you have 11.8V on shutting down the ignition you have serious problems.
13th Dec 2012 5:40pm |
Go on.............. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
13th Dec 2012 10:11pm |
To continue...
14th Dec 2012 10:24am |
Thanks NDFI
Can't see how this would make a circuit? If you mean item 6 on image below?
14th Dec 2012 10:59am |
No not the battery side of the jump post, the cable on other side of the panel that drops down to the starter / alternator.
14th Dec 2012 11:17am |
So, you mean remove cable (1) from jump post (2) then connect ammeter between (1) and (2) ?
15th Dec 2012 4:14pm |
