Home > Technical (L322) > Pre heat |
Standard though a lot will likely have the fob missing for it so just buy another and sync it up and jobs a good en FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
11th Dec 2012 3:32pm |
Standard? Really? Not here AFAIK...
11th Dec 2012 3:59pm |
Every TDV8 should have it from the factory, especially in any country where the temps can be quite low as the TDV8 needs the help to warm up may not have come with the park heat function but its a doddle to enable isnt it FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
11th Dec 2012 4:36pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
doesn't it need a remote receiver fitted for the 'remote fob' function to work... ... - .- -.
11th Dec 2012 4:38pm |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 |
I thought pre-heat was set from the head unit (the one i'm currently thinking about ripping out DOH!) |
11th Dec 2012 4:55pm |
'timed' preheat yes but if you have a remote receiver and a remote fob you can switch the fbh on whilst indoors.. ... - .- -.
11th Dec 2012 5:17pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
My Vogue se has it with the remote. Wouldn't be without it.
11th Dec 2012 6:03pm |
keep the older version and peeps will think you're well endowed.. ... - .- -.
11th Dec 2012 8:04pm |
Stan
11th Dec 2012 8:15pm |
11th Dec 2012 8:16pm |
You have to differentiate: every diesel FFRR has a FBH. They are used as auxiliary heaters to augment the cabin heat on cold days because the diesel is so durned efficient that there is almost no waste heat You can not pre-heat with this tho. Unless you enable the 'Park heat' function. Which yes, now is a doddle to activate... But 'Park Heat' was an option - and not inexpensive given what LR actually 'added' to the vehicle... RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
11th Dec 2012 9:34pm |
Yes, that would be another disadvantage. Do you have timed heat in the menu? RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
11th Dec 2012 9:36pm |
mark_j Member Since: 11 Dec 2012 Location: somerset Posts: 78 |
Ok, i know that all diesels have the FBH, but the remote was an option, how do i tell if this is installed and they have just lost the remote, or if it does not; and never did have the receiver fitted? |
12th Dec 2012 9:17am |
http://www.fullfatrr.com/forum/topic15276.html
12th Dec 2012 9:40am |
