![]() | Home > Technical (L322) > Urgent Help |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Help
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Gear selector in park? Battery fully charged? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Sorry did not explain right dash is dead no warning lights but key will turn radio sat nav etc all ok and seat set to position but i have just had battery disconnected for a bit to reset still no good canit lose key pairing for immobiliser?
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
Why not try disconnecting the battery again for 5 minutes and try again.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 ![]() ![]() |
sounds like an under powered battery.. ... - .- -.
Don't think so as its the transponder in the key that does the imobilising I thing an if its unlocking the steering that should be ok. Put your battery on charge and try in the morning. These things have a habit of just fixing themselfs. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Its had a few good runs as was ok exept for fan until i pulled fuses. Strange there is nothing no warning lights on the dash nothing????? Mine was a blue one! |
Are all the fuses ok and in properly |
Going to have to wade through them in the morning what a crap week ! Should never have touched it fu*k Mine was a blue one! |
I remember reading on l322.co.uk when he removed a certain fuse he had to be recovered and it needed plugged in to reset |
Oh joy only removed and checked the ones listed on here to do with the fan but when i put the 10 amp one back in it stirred the electronics up Mine was a blue one! |
Sound like when you have put the fuse back you may have given that system a belt or something. Put on charge overnight so you know the battery is full, and pull the fusee you pulled the first time. In the morning check all the fuse's and replace them. Then put the battery fully charged back on. I would also think about touching both battery cables together first to ensure its fully flat and all ECU's are discharged but I'm not 100% sure that's the correct thing to do. Hopefully someone else will give some guidance on that? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Re checked fuses and had battery leads shorted together when disconnected Mine was a blue one! |
Been on charge all night no change checked instrument fuse (1) thats ok
