Home > In Car Electronics (L322) > Displaying Arrival Time On The Mk4 Sat Nav.........
mjdronfield
......how do you get it to tell you the estimated time of arrival at the bottom of the screen ?
I just have "Time" and then dashes.........
Is this normal ?
Cheers 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #155563 5th Dec 2012 3:19pm
You dont mean the clock time bottom right?
Post #155585 5th Dec 2012 6:02pm
mjdronfield
Just been out to have another look.
Apologies, it doesn't say time, must have been the TMC I was thinking of.
Its next to the arrow and the dot........
Just has dashes and pm.........had a route planned....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #155592 5th Dec 2012 6:49pm
mjdronfield
from looking on the bmw forums, it looks like you have to code the nav to the car...........
not sure an l322 vin will be valid........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #155660 6th Dec 2012 12:03am
mjdronfield
OK, just spent half hour with Navcoder, and that was waiting for comms to start on the usb from my laptop, have selected L30 Range Rover, the VIN was queried correctly, ticked the box that says "Show Arrival Time", but then it said only for E39 something, coded the nav module and it still doesn't work.
So unless someone has upgraded to Mk4 nav and has the arrival time working, I'm guessing it can't be done........
Mmmmm. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #155987 7th Dec 2012 4:24pm
RichardP
You need to set the Nav clock for it to give you an arrival time. Go to the settings menu and set the time and date - when set it should adjust the analogue clock in the dash, if not set the analogue clock will continue running and can still show the righttime. When set, you should see the time in the bottom left corner.
Post #156161 8th Dec 2012 6:49pm
mjdronfield
Thanks Richard.
I shall try that, but as the unit has been in for just over 12 months now, I will have changed the time when the clocks moved forwards and backwards. Worth a try again though.
Are you the RichardP of E39 M5 fame ? as I'm pretty sure I sat next to you at lunch time in the pub during the M5 meet at Curdworth in May 2009..........
I have the Mk4 unit you helped Danny Otter with.......
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #156162 8th Dec 2012 6:56pm
RichardP
Make sure you set the date too.
Yes, I am the the M5 RichardP, that meet was a while ago now! Danny got and M5 not long after, but I think he only kept it 6 months or so.
Post #156176 8th Dec 2012 8:26pm
mjdronfield
He kept it about 18 months if I remember right, I drove it a few times. He swapped it for a petrol 2003 Range Rover Vogue, paid £11k for it and sold it after 6 months for £5k as the gearbox was on the way out, and he didn't have enough money to fix it.
He then had a Volvo S60 diesel for a bit and last month bought a 2003 Discovery 2 Td5 ES......
I shall prob see him next weekend.
Are you in a Range Rover now ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #156179 8th Dec 2012 8:38pm
RichardP
No, no, still the same M5!
Post #156180 8th Dec 2012 8:48pm
mjdronfield
Just entered the time and date again this morning, and it says the time OK at the bottom left of the display, but the arrival time is still not shown.
Further to that, I now have "BMW ASSIST" as an option in the menu, which wasn't there before, and is obviously no use to me.
Does anyone know what I need to do with Navcoder to get rid of it ?
Is it talking to the ULF phone unit ? Does that need recoding too ?
20 questions...........!!
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #156465 10th Dec 2012 3:21pm
RichardP
Not sure how you've managed to get the Assist option, did you change the 'BMW Assist' option in NavCoder?
Have you tried with both settings of 'Show Arrival Time' in NavCoder? If this setting is wrong either way you don't get the arrival time.
Post #156475 10th Dec 2012 4:06pm
i'm thinking you might have a bmw map disc ,hence the 'assist' option.. ... - .- -.
Post #156477 10th Dec 2012 4:10pm
mjdronfield
I believe the unit originally came from an X5. The chap I bought it off had the Range Rover splash screen added......
Thinking on, it may have had "Emergency" in red before, and all that was added when I put the bluetooth ULF module in to get "Telephone".........around Feb time.
MMmmmm
Over the weekend I changed the setup from an X5 to a L30 Range Rover with Navcoder . in trying to get the arrival time to work. I think all its done is "European-ised" the text, so Emergency is now BMW Assist........
Are there any other type of map disk for the Mk4 ? as it was never officially fitted in an RR ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #156486 10th Dec 2012 4:42pm
indeed the mk4 is a bmw unit..have you downloaded Matts firmware from his site? ... - .- -.
Post #156489 10th Dec 2012 4:54pm
