![]() | Home > Maintenance & Mods (L322) > new battery ...95ah or 110ah |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Update: Got up this morning with new resolve to get the |
Mine was a very tight fit also but it's doable with a little persistence. Present :2008 TDV8 HSE
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
It's in the Wiki
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 ![]() ![]() ![]() |
Am seriously hacked off.....
Any LR independent I would have thought? |
If you struggle I'm not that far awy and don't mind lending a hand or two if you just need someone to so the lifting bit |
You mean like JD Automotive in Northwich?? Cheshire's leading Land Rover Specialist???.... Thanks for the reply - I was hoping somebody might have first hand experience of somebody that will do this... |
That's incredibly kind of you... I think I've got to the stage where I would just rather pay a fair rate to somebody for doing the job - but what a wonderful gesture - thanks again |
Are there any other independents or phone local main dealer and ask how much to swap a battery.... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
Pretty much any mechanic worth his salt should be able to do it - doesn't need to be a LR specialist.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6761 ![]() ![]() ![]() |
I fitted my Bosch S5 the other day and removed the flanges off the sides of the battery. At first I was convinced it still wouldn't fit due to the explosive fuse on the +ve side, but a bit of fiddling got it in and both clamps are back on and screwed down tight. I also removed the earth strap to make it eaiser to locate it and refitted it once the battery was in place. It is a VERY tight fit, but definitely fits.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
TBH i tried and although im convinced it probably would fit, as many people also have done it, i opted for the Bosch S5 100AH version, and so far it seems to be perfectly OK. and its the same size as the original so fits first time no swearing or trimming required, 5 min job. |
Thanks for all of the helpful comments guys, but we're getting a bit off topic here.
I think that because you need to removed the flanges (cut off to be more specific) from the sides of the battery, no garage will accept libility for doing this, so unless you have a "friendly" mechanic you know, going in cold and asking them to do this for you won't work. Got - 2017 SDV8 Autobiography in Loire Blue
