Home > Technical (L322) > Headlights misaligned??
Arenaitch
I'm starting to get a noticeable number of cars flashing to suggest my headlamps are on full beam when they're not, but the dipped beam is very high, certainly shines directly into cars which doesn't look right to me
I have also noticed that my xenons - unlike other cars I have had with them fitted - do not give the 'alignment jiggle' when switched on. However, I have not noticed up to now if they ever did that.
So, question.... should my headlights go through the alignment check process when first switched on?
And do RR headlights in general shine direct into other cars as a norm, or is just a 'feature' of mine? 2012 FFRR Westminster Orkney / Ivory and absolutely no pimp-glass!
Post #155016 3rd Dec 2012 8:47am
The headlights don't have an interior toggle or alignment mechnism like other cars as the suspension is designed like citroens better cars in that it self levels so no correction is required as the requirement is that the headlights should be able to maintain the correct alignment regardless of suspension load, accomplished by the level self levelling Smile
There maybe something on the back of the unit for some adjustment but i dont recall seeing it im afraid when ive taken my units out Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #155019 3rd Dec 2012 8:54am
Take it into the dealer and have them check the alignment.
Post #155022 3rd Dec 2012 8:56am
