Home > Off Topic > Help with LED external Xmas Lights |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
If they are genuinely dimmer the only thing that is likely to cause that is low voltage, but it would have to be pretty low.
2nd Dec 2012 5:43pm |
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 |
Thanks
2nd Dec 2012 5:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
have the lights got a controller , if so that might be faulty...normally leds ar eon or off unless a controller of some form makes them dim. ... - .- -.
2nd Dec 2012 6:21pm |
Arenaitch Member Since: 27 Aug 2012 Location: Twixt Scummers and Skates Posts: 69 |
Wot he said - LEDs are either on or off - never 'dim' except if that is the maximum output they can manage - ie I do not believe you can get variable output LEDs 2012 FFRR Westminster Orkney / Ivory and absolutely no pimp-glass!
2nd Dec 2012 6:25pm |
Interesting,
2nd Dec 2012 6:46pm |
leds do dim but needs some electronic stuff to do it , ie a controller.. ... - .- -.
2nd Dec 2012 7:48pm |
Hmm..m,
2nd Dec 2012 8:10pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 |
my understanding is that led dimmers unlike halogen dimmers actually rapidly switch the lamp on and off rapidly reducing the total amount of light emitted - to our eyes it looks dimmer. you can see this illustrated when you shoot video of dimmed leds. apparently this is called Pulse Width Modulation and allows brief periods of full voltage to the leds. |
^^^ I agree, noticed that myself, but for some reason some led Drls use resistors. |
2nd Dec 2012 8:14pm |
I just thought that LEDs had a trigger voltage/current that produced a 'fixed' output and that it was not possible to actually vary directly as it is the chemical make up of the LED itself that controls the lumens produced?
3rd Dec 2012 8:03am |
back to Stormins question, i reckon clean the connections and check the power supply and if it does have some kind of controller , check that.. ... - .- -.
3rd Dec 2012 8:28am |
Thank you every one for all your suggestions, managed to get home from work whilst it was still light today.
5th Dec 2012 5:12pm |
