Home > Maintenance & Mods (L322) > Broken seat plastic side trim |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
As this seems to happen quite alot, I knew I was on borrowed time, and 9 years of use has finally broken the drivers seat trim, the one at the side, enclosing the electric seat switches.......
2nd Dec 2012 9:55am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8621 |
can the plastic be glued back together with strong adeshive, i use carpenters mitre fix for quite a lot of repairs around the place and it sticks well, glue and activator pack available from screwfix, b and q, magnet, howdens and most hardwarey type places.
2nd Dec 2012 10:29am |
Cheers mate.
2nd Dec 2012 10:45am |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
if you can get the trim of, great.. I repaired both my friends by gluing a washer behind the trim with some epoxy, you can build it up and bet plenty on as it is all hidden. V8 facelift Range Rover Autobiography 22" wheels.
2nd Dec 2012 1:07pm |
Ah..........good idea.
2nd Dec 2012 1:48pm |
I think it was a m5, remember to key the area well , after they dried we painted the front black to match the trim and it was as good as new, in fact better as you don't have to worry about the bolt pulling through.. V8 facelift Range Rover Autobiography 22" wheels.
2nd Dec 2012 1:59pm |
Thanks Dave.
2nd Dec 2012 2:14pm |
its one of those trims that when you get it off it all comes clear, you don't need a screwdriver as you can do it with your finger, just take your time and don't force it, start with the clip at the front.. V8 facelift Range Rover Autobiography 22" wheels.
2nd Dec 2012 3:49pm |
