Home > Technical (L322) > Cornering lights, my2006
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Hi guys,
I have ran a search for this problem but cant find any help. So any pointer will be greatly appreciated.
The other day my battery went flat, just an old battery. no problem i replaced the battery and reset the steering, all seemed fine. Now driving in the dark i have noticed my cornering lights are not working.
I checked for faults, all the common ones for low voltage ect, reset fine, no current faults other than traffic system, Ariel circuit or some such. But still no cornering lights.
I have also tried the disconnect and reconnect the batt as per the wiki.
I have an iid tool but cant seem to find anything in the ccf relating to the cornering lights.
So i am out of ideas, any pointers will be very much appreciated.
Kind regards, Luke
Post #154742 1st Dec 2012 6:32pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
After the battery disconnect and reconnect you need to start the car and move the wheel through it's full range. It helps to hold it at each extreme for a few seconds too. This helps the car calibrate it's wheel position sensors and this is probably linked to the cornering lights.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #154767 1st Dec 2012 7:48pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
My cornering lights have never worked !!!! Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #154774 1st Dec 2012 8:15pm
barracuda816
Thanks for the reply, but i did this as art of the batt reconnect. Alas to na avail. Big Cry
Post #154777 1st Dec 2012 8:17pm
barracuda816
Does any one know what the LCM needs for this function?
Im just thinking if all the LCM needs is info from steering position sensor than why is this such a common fault.
Finally, if this is the LCM can it be reflashed?
Regards, Luke
Post #155144 3rd Dec 2012 7:38pm
