Home > Technical (L322) > jump start advice |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
is this any help,
27th Jul 2012 1:06pm |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 |
thats fantastic...
27th Jul 2012 1:08pm |
....and then ,with the engine running, turn the steering wheel fully left and then fully right to set the steering parameters... ... - .- -.
27th Jul 2012 1:34pm |
Nick66 Member Since: 21 Aug 2012 Location: Notts Posts: 18 |
I think I also have a flat battery, have come to jump start and the manual I have shows the 2006 pic in the above post but I can't find the + connection point outside the battery compartment.
30th Nov 2012 2:34pm |
Yes it should work fine, just make sure the jump leads are heavy enough and properly connected |
30th Nov 2012 2:37pm |
Thanks |
30th Nov 2012 2:40pm |
And also don't turn the key until you've given it a few minutes to get some decent charge in it otherwise it will crank and die just before it catches:( Being a TDV8 before you even crank there will be a huge drain. Make sure lights are turned off and not left to auto, interior fans are off and lights as well.
30th Nov 2012 3:02pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
Check the actual battery for + and - as the pictures look opposite to my tdv8..... There is nothing that can't be fixed with a hammer😜😜
30th Nov 2012 7:38pm |
The picture is WRONG the positive is always on the other side! |
30th Nov 2012 7:42pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
1st Dec 2012 10:26am |
I thought the lock to lock steering procedure was only for 2002-2005 MYs and not for the MY 2006 and onwards ?? Can someone please check and confirm ??
1st Dec 2012 10:45am |
Thanks for all the advice, much appreciated. Just a quick update.
1st Dec 2012 1:35pm |
Seems pretty good, a genuine rr battery is about £150, but a bosch one is available which will fit fpr about £70 after discount and for a slightly larger one £99ish
1st Dec 2012 2:03pm |
