Home > Maintenance & Mods (L322) > Heater not getting as hot as it used to....
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
As title - noticed the heater is not getting as hot as i remember (could be a senior moment). The engine temp is fine and the AC works (cools) but when I want it in automatic mode and heat I get warm air but not as roasting hot as I remember? Are there any known issues like this? Had a search and the only ones I came across are FSR but that resulted in no blower at all which is not what I am seeing. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black β€”β€”β€” Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #154026 28th Nov 2012 9:27am
One idea.....there is a valve in the coolant system which regulates the ammount of water through the heater matrix, its located in the engine bay on the front passenger side innner wing. This may be the source of the problem, if you have dual zone heating (passenger/driver) are both of them heating the air the same amount or is one cooler/warmer. There is a valve for both sides of the cabin in the dual zone climate systems so if one heats fine then this could point towards the vlave as the problem. not definitive though.
As a simple fix do you have the blower temperature thumbwheel under the hazzard switch set to hot too? Whistle There is nothing that can't be fixed with a hammer😜😜
Post #154394 29th Nov 2012 6:34pm
fisha
How hot are you setting the temp when in auto mode?
I found that unless you had the desired temp set quite high ... say about 24 or above, then the warm air meant to heat the cabin wasn't terribly hot.
failing that:
As already mentioned, the hot coolant to heat the matrix is controlled by the valves on the passenger engine wing. I found that the wires would dry up being close to the exhaust manifolds and a little removal of the connector and reseat made a bit of a difference.
Also, checked your coolant level? If its low, the coolant reaching the heater isn't all that great unless the engine is revving well. Also if its nose down, you might notice the heater cool as well. V8 or else ...
Post #154432 29th Nov 2012 9:05pm
Diver Bryn
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Had the same issue after changing my coolant, hot air was very cool, turned out to be an air lock after a couple of system bleed's, problem was satisfactory resolved. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Renault Fuego 2 ltr TX
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Volvo 740 TDi Estate
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Land Rover Discovery 3 TDV6
Mini Cooper Diesel
Mercedes Vito Van 111
Range Rover TD6
VW Golf 2ltr GTD 2015 Year
2016 Audi Q7 Sline 3ltr 272Bhp
Post #237464 27th Jan 2014 3:47pm
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
could be an air lock,might have to bleed the system,this can happen on any vehicle ...on my 2005 vogue there is a bleed nipple that sits next to the main inlet cap,its just a matter of starting the range,making sure the heating is totally off,let the vehicle get hot,go back into the cabin,turn the heating all the way up and the heating thermostat all the way up,so the heating is at its maximum ,go back in the engine bay with the engine running and undo the bleed nipple please, please do this very ..SLOWLY,as the system is now pressurised and by rushing the procedure you'll get a jet of hot water into your face and the chance of loosing the bleed nipple as it will fly off by the pressure built up behind it,after a few twist of the the nipple using a flat headed screw driver you'll hear the sound of trapped air hissing out,stop unscrewing and hang tight till you hear the sound change from that of air being forced out to that of a watery sound coming out,screw the nipple back...its similar to bleeding a house radiator...when its all cool back down a while later,check to see if the system has the right amount of coolant,twist the cap and you'll see a stick float pop out all way if there is sufficient coolant inside,if it doesn't it means you need a top up,please refer to manufacture hand book or wiki for which coolant to use...
steve
Post #237498 27th Jan 2014 5:47pm
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Hi to all.Problem that i am facing with heating is that i can only have really hot air.What i mean is that fr having hot air in car both temp knobs should be turned to max temp.If i will reduce temp even by one degree to co driver's side then all codriver's grills and also back seats grills are blowing cold air ,while driver's grills are still blowing hot air still max.Same happens if i will let codriver's temp knob to max and reduce temp fm driver's temp knob.
Since cold air starting to blow even if turn knob once again back to max air still remains cold.Funny story is that i am with impression that will start once again to blow hot air only if i will reduce car 's speed to 0kms (but i have to make it sure/retest it).I have been to all rr representatives fr fixing this problem/they have changed whatever sensor/valve is possible but not any solution.
Only that i have not changed is the heating control panel in car
Any ideas guys?????????
Post #237907 29th Jan 2014 12:10pm
Gsxr1250dave
Finally found some one who has had the same problem I'm having with my 4.4 m62 trouble is its a 2014 post with no resolution Big Cry Big Cry
Post #502814 26th Jan 2019 1:04am
Gsxr1250dave
This post doh
Post #502815 26th Jan 2019 1:04am
