Home > Technical (L322) > PROBLEM SOLVED No Power to Front passenger door?
mick79
2004 Range Rover Vogue 4.4 V8 Java Black
Hi,
Just found this site Hope someone can shed a bit of light for me,
Used car yesterday after the missus decided to clean the interior and flatten the battery Rolling Eyes
Fully charged the battery straight away is only 9 months old. drove it yesterday and tried to adjust the mirror and wouldnt work, so tried the window and no luck there also the door will not lock or open with the fob have to press the button maually to lock and pull handle inside to open. Anyone else had this prob?
Cheer Mick Owner of a bottomless pit, Sorry i mean range rover l322.
Post #153402 25th Nov 2012 6:51pm
mick79
bump Owner of a bottomless pit, Sorry i mean range rover l322.
Post #154191 28th Nov 2012 8:47pm
Is it just the one door and mirror and window that is not working? Is the fob locking all the other doors? Previously..
Post #154194 28th Nov 2012 8:56pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
I have not come across this problem by simply getting a flat battery. a couple of questions that may help diagnose it:
Can you operate the passenger windows from the drivers control?
Can you operate either mirror?
All other locks and windows work as normal?
Do the puddle lights work?
Do you have any fault codes in the BCM? (assuming you have an IID tool or similar, If not than i would seriously look at getting one if you plan to keep the range rover for any length of time)
Also have you tried a battery disconnect and reset, although this is unlikely to help if you have none of the above as they are controlled by different control units.
regards, luke
Post #154196 28th Nov 2012 9:00pm
mick79
Yeah it's just the one door, all other windows are fine and yes the fob locks all the other doors.
Cheers Mick Owner of a bottomless pit, Sorry i mean range rover l322.
Post #154209 28th Nov 2012 9:23pm
mick79
regards, luke
Hi,
The puddle lights work fine, all other locks and windows are fine, I cannot operate window or mirror from the drivers side. Drivers side mirror works fine.
An iid tool is my next purchase, just trying to source the best price for one.
Post #154212 28th Nov 2012 9:31pm
It sounds like the connector has come loose in the door. If you have that many faults in one door I would think it would be something straight forward like that. Previously..
Post #154213 28th Nov 2012 9:35pm
mick79
That's my first point of call this weekend, I kind of thought the same, thought I'd ask the question here as we all know how weird the electrics behave on a ffrr. Thought it may have been mentioned before.
Cheers mick Owner of a bottomless pit, Sorry i mean range rover l322.
Post #154215 28th Nov 2012 9:40pm
There are videos on youtube that show you how to strip the door down. Thumbs Up Previously..
Post #154222 28th Nov 2012 10:17pm
mick79
Thank you for that much appreciated. Thumbs Up
Post #154228 28th Nov 2012 10:33pm
have a look on out wiki Mick, the info is there... ... - .- -.
Post #154264 29th Nov 2012 8:17am
mick79
Problem solved, bought myself a new battery charger a ctek multi 7.0 nice piece of kit. Stuck the battery on charge again put it back on this evening, and all is well took it out for a leisurely drive no faults all door locks and windows working fine.
Cheers for all your help guys.
Post #154652 30th Nov 2012 11:00pm
mick79
Problem solved Owner of a bottomless pit, Sorry i mean range rover l322.
Post #156218 8th Dec 2012 11:21pm
holidaychicken
I had this problem after getting a flat battery a few times while working on my car and also having the alarm going off and not being able to stop it as battery went too flat. i also disconnected the battery backup sounder for the alarm. When i charged the battery on the vehicle and started using it i had no power going to the passenger door and no BCU faults on the all comms but my faultmate didn't like connecting to the BCU.
I was checking fuses again by actually removing them to test rather than connecting a meter across them and when i removed fuse 15 to check it i got a continuous very loud beep from the alarm sounder i think and when i replaced the fuse the noise stopped and the door worked again !
Just thought i would share that with the group.
i think a battery disconnect would achieve the same result.
Post #483445 14th Jul 2018 5:38pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Appreciate it’s an old thread but just had this on mine after alternator death.
Battery disconnect didn’t solve it but pulling fuse 15, which put the sounder on, and putting it back did reset the system.
Fuse was fine as I had tested it previously but just hadn’t pulled it. Doh!
I only did this after taking the door card off and disconnecting the A pillar to door wiring - which was a PITA.
Post #553942 15th May 2020 10:03am
