![]() | Home > Wheels & Tyres > Tyres 285 35 22 |
I have some Atturo, review here for what it's worth. |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
Are the Toyos 106 weight rating upto the FFRR then? What is the weight rating needed for the rangerover? |
So 106 or above are fine for a FFRR then? must be loads lighter than a D3 |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I'm not sure, but I thought RR wheels were rated to 1050, so I'd assume you'd want tyres to match. If you corner hard in a RR then you tend to load up the front tyre you're turning on, which would put quite a bit of weight on it ... |
Thats what i thought. Is i possible to find out the recomended weight rating. Speed rating less of an issue for me and my TD6 |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Comes with 111 as standard. Well, my td6 did. Previously..
MMM the plot thickens |
